An announcement for the Android users amongst us
Post(s) 0-17 are missing from the archive :(
thegreck @OneDream 3 March 2016, 19:00 UTC
@OneDream Pretty much, but checking the battery life is a pretty big one. I use it constantly to see where I'm at on battery life while riding, otherwise you get yourself stranded somewhere and have to lug a 25-pound brick to the nearest outlet.
Aswellie @dontfeedthenerd 3 March 2016, 19:05 UTCA
@dontfeedthenerd Motorola Moto X Gen 1 running android Lollipop 5.1
Aswellie @OneDream 3 March 2016, 19:06 UTCA
@OneDream You can see how fast you are riding if you are brave enough to look at your phone while riding.
knight32 3 March 2016, 19:35 UTCK
Thank you!!!! It works on my Note 5
Electric Slide 3 March 2016, 20:34 UTC
THANK YOU!!!!! :clap: :clap: :clap:
oledokka @fabuz 3 March 2016, 22:21 UTC
@fabuz works like a dream on Nexus 6 with latest Android version.
njcustom 3 March 2016, 23:24 UTC
Very happy!!
parrothd 4 March 2016, 00:59 UTC
Now everyone just needs to send an email asking for a battery level alert!
For example at 50% vibrate and notification...
dontfeedthenerd 4 March 2016, 01:04 UTCD
Would be awesome to have Android Wear support eventually too :P
Mmarauders89 4 March 2016, 10:10 UTC
Awesome! Finally get to ride onewheel to its full potential! It was fun riding normal mode, but once you ride in extreme you'll never go back! Love that i can turn lights off. Thanks FM, keep up the good work!
RentOnewheel 4 March 2016, 10:17 UTC
This Android-App works only on mobile phone with Android Version 5. Any other guys don't see the App in Google-Play-Store, because the App is incompatible. I wrote a mail to Jack last day.
I hope that the developer compile the App again for all phones with Version 4.2.1 and above. Best regards from Germany. -
bmtka @RentOnewheel 4 March 2016, 11:08 UTC
@RentOnewheel They told you that it only works on version 5.0 (Lollipop) or above? That is a bummer for a large percentage of users and if they aren't planning on making the app more backwards compatible, they should make it clear to current owners and potential buyers what the minimum specs are. Luckily, the app works mostly fine on my Nexus6P--though it did crash at least once yesterday. Did you get any sense that this "Jack" actually develops the Android app or is he some dude who is just tasked with communicating with us about the Android app?
RentOnewheel @bmtka 4 March 2016, 13:21 UTC
@bmtka Jack isn't the developer of the app, he is an employee of onewheel and my communication partner concerning the Onewheel.
TonyGDTLA @thegreck 5 March 2016, 00:21 UTC
As do I. But I've gotten pretty good at reading the power button light for battery level. With in 5-10%.
parrothd 5 March 2016, 05:43 UTC
I've spent about 5 hours trying to get the android tasker app to monitor the onewheel app and alert me when battery falls below 50%. Think I've finally got that something that works, still lots of bugs though..
bmtka @parrothd 5 March 2016, 06:08 UTC
@parrothd Oh yeah? Care to share your profile as it evolves?
thegreck @TonyGDTLA 5 March 2016, 06:59 UTC
So...
- How does that work?
and - How can you see your power light while riding?
parrothd @bmtka 5 March 2016, 16:49 UTC
@bmtka Sure, it's been a while since I've used tasker but I think I have the basic logic down.
This is on my nexus 6. Basically I've tried everything to get the battery percent out of the app, however they way they wrote it(just like the IOS app) you can't do much with it. So I switched gears and went another direction.
I have tasker open the app and then use the autoinput plugin to get 1 pixel screen shot from the main battery power meter screen. If it's color #445366 which is the background depending on where I get the pixel from tells me the color change/height of the power meter.
I can post an export if wanted..
tasker
autoinput plugin
secure settings
rainynite @parrothd 5 March 2016, 17:13 UTCR
@parrothd Dude that's very creative. Yah if you could upload the export I'll see if I can play with it as well. Get it to send a notification to my Gear S2 watch and no more worrying about battery-life.
Thanks!!
bmtka @parrothd 5 March 2016, 19:37 UTC
@parrothd That is actually really clever. Many of my trusty Tasker profiles go unused since much of that functionality is built into Android these days. I will give it a shot.
parrothd 5 March 2016, 21:12 UTC
You need to tweak the pixel location, for my phone it's probably different, I've been testing around 90% alert... :)
TaskerData sr="" dvi="1" tv="4.8u1m">
<Profile sr="prof2" ve="2">
<cdate>1457055617603</cdate>
<clp>true</clp>
<edate>1457191519609</edate>
<id>2</id>
<mid0>3</mid0>
<nme>Battery Mon1</nme>
<App sr="con0" ve="2">
<cls0>com.rideonewheel.onewheel.ui.splash.OWSplashScreen</cls0>
<flags>2</flags>
<label0>Onewheel</label0>
<pkg0>com.rideonewheel.onewheel</pkg0>
</App>
</Profile>
<Task sr="task3">
<cdate>1457055628207</cdate>
<edate>1457191362880</edate>
<id>3</id>
<nme>Test</nme>
<pri>100</pri>
<Action sr="act0" ve="7">
<code>549</code>
<Str sr="arg0" ve="3">%batt</Str>
<Int sr="arg1" val="0"/>
</Action>
<Action sr="act1" ve="7">
<code>547</code>
<Str sr="arg1" ve="3">1</Str>
<Int sr="arg2" val="0"/>
<Int sr="arg3" val="0"/>
</Action>
<Action sr="act10" ve="7">
<code>28028</code>
<Bundle sr="arg0">
<Vals sr="val">
<CaptureMode>0</CaptureMode>
<CaptureMode-type>java.lang.String</CaptureMode-type>
<CatpureAudio>false</CatpureAudio>
<CatpureAudio-type>java.lang.Boolean</CatpureAudio-type>
<CatpureScreenshot>/storage/emulated/0/AutoInput/screencapture.png</CatpureScreenshot>
<CatpureScreenshot-type>java.lang.String</CatpureScreenshot-type>
<CompareTo><null></CompareTo>
<CompareTo-type>java.lang.String</CompareTo-type>
<Crop><null></Crop>
<Crop-type>java.lang.String</Crop-type>
<Duration>0</Duration>
<Duration-type>java.lang.String</Duration-type>
<File>/storage/emulated/0/AutoInput/screencapture.mp4</File>
<File-type>java.lang.String</File-type>
<Palette>false</Palette>
<Palette-type>java.lang.Boolean</Palette-type>
<PixelColor>800,405</PixelColor>
<PixelColor-type>java.lang.String</PixelColor-type>
<Resolution>2</Resolution>
<Resolution-type>java.lang.String</Resolution-type>
<com.twofortyfouram.locale.intent.extra.BLURB>Screenshot Path: /storage/emulated/0/AutoInput/screencapture.png
Pixel Color : 800,405
Palette: false
Get Average Color : false</com.twofortyfouram.locale.intent.extra.BLURB>
<com.twofortyfouram.locale.intent.extra.BLURB-type>java.lang.String</com.twofortyfouram.locale.intent.extra.BLURB-type>
<net.dinglisch.android.tasker.RELEVANT_VARIABLES><StringArray sr=""><_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES0>%aifiles()
File Paths
File Paths of the selected files.<br/>Will contain only the selected files (video or screenshot)</_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES0><_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES1>%aiscreenshotfile
Screenshot Path
Path where the screenshot was saved</_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES1><_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES2>%aiscreenshotpixelcolor
Screenshot Pixel Color
Color of the pixel in the specified coordinates in the hexadecimal format</_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES2><_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES3>%aivideofile
Video Path
Path where the video of the screen capture was saved</_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES3><_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES4>%err
Error Code
Only available if you select <b>Continue Task After Error</b> and the action ends in error</_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES4><_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES5>%errmsg
Error Message
Only available if you select <b>Continue Task After Error</b> and the action ends in error</_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES5></StringArray></net.dinglisch.android.tasker.RELEVANT_VARIABLES>
<net.dinglisch.android.tasker.RELEVANT_VARIABLES-type>[Ljava.lang.String;</net.dinglisch.android.tasker.RELEVANT_VARIABLES-type>
<net.dinglisch.android.tasker.extras.VARIABLE_REPLACE_KEYS>FieldsToGet CompareTo PixelColor Crop CaptureMode Resolution Bitrate File Duration CatpureScreenshot plugininstanceid plugintypeid </net.dinglisch.android.tasker.extras.VARIABLE_REPLACE_KEYS>
<net.dinglisch.android.tasker.extras.VARIABLE_REPLACE_KEYS-type>java.lang.String</net.dinglisch.android.tasker.extras.VARIABLE_REPLACE_KEYS-type>
<net.dinglisch.android.tasker.subbundled>true</net.dinglisch.android.tasker.subbundled>
<net.dinglisch.android.tasker.subbundled-type>java.lang.Boolean</net.dinglisch.android.tasker.subbundled-type>
<plugininstanceid>c830bf45-1b68-4faa-bf44-4d087e966924</plugininstanceid>
<plugininstanceid-type>java.lang.String</plugininstanceid-type>
<plugintypeid>com.joaomgcd.autoinput.intent.IntentScreenCapture</plugintypeid>
<plugintypeid-type>java.lang.String</plugintypeid-type>
</Vals>
</Bundle>
<Str sr="arg1" ve="3">com.joaomgcd.autoinput</Str>
<Str sr="arg2" ve="3">AutoInput Screen Capture</Str>
<Int sr="arg3" val="200"/>
</Action>
<Action sr="act11" ve="7">
<code>171</code>
<on>false</on>
<Int sr="arg0" val="7326"/>
<Int sr="arg1" val="302"/>
<Int sr="arg2" val="50"/>
<Int sr="arg3" val="3"/>
</Action>
<Action sr="act12" ve="7">
<code>61</code>
<Int sr="arg0" val="200"/>
<ConditionList sr="if">
<Condition sr="c0" ve="3">
<lhs>%aiscreenshotpixelcolor</lhs>
<op>0</op>
<rhs>#445366</rhs>
</Condition>
</ConditionList>
</Action>
<Action sr="act13" ve="7">
<code>171</code>
<Int sr="arg0" val="8000"/>
<Int sr="arg1" val="1000"/>
<Int sr="arg2" val="90"/>
<op>2</op>
<rhs>#445366</rhs>
</Condition>
</ConditionList>
</Action>
<Action sr="act14" ve="7">
<code>548</code>
<Str sr="arg0" ve="3">%aiscreenshotpixelcolor</Str>
</Action>
<Action sr="act15" ve="7">
<code>16</code>
</Action>
<Action sr="act16" ve="7">
<code>30</code>
<Int sr="arg0" val="0"/>
<Int sr="arg1" val="30"/>
<Int sr="arg4" val="0"/>
</Action>
<Action sr="act17" ve="7">
<code>135</code>
<Int sr="arg1" val="2"/>
<Str sr="arg2" ve="3"/>
</Action>
<Action sr="act2" ve="7">
<code>30</code>
<Int sr="arg1" val="3"/>
</Action>
<Action sr="act3" ve="7">
<code>11820</code>
<Bundle sr="arg0">
<Vals sr="val">
<com.intangibleobject.securesettings.plugin.extra.BLURB>Screen & Keyboard Lights On
1 Second</com.intangibleobject.securesettings.plugin.extra.BLURB>
<com.intangibleobject.securesettings.plugin.extra.BLURB-type>java.lang.String</com.intangibleobject.securesettings.plugin.extra.BLURB-type>
<com.intangibleobject.securesettings.plugin.extra.SETTING>wake_device</com.intangibleobject.securesettings.plugin.extra.SETTING>
<com.intangibleobject.securesettings.plugin.extra.SETTING-type>java.lang.String</com.intangibleobject.securesettings.plugin.extra.SETTING-type>
<com.intangibleobject.securesettings.plugin.extra.WAKE_LOCK_DURATION>1000</com.intangibleobject.securesettings.plugin.extra.WAKE_LOCK_DURATION>
<com.intangibleobject.securesettings.plugin.extra.WAKE_LOCK_DURATION-type>java.lang.Long</com.intangibleobject.securesettings.plugin.extra.WAKE_LOCK_DURATION-type>
<com.intangibleobject.securesettings.plugin.extra.WAKE_LOCK_TYPE>full</com.intangibleobject.securesettings.plugin.extra.WAKE_LOCK_TYPE>
<com.intangibleobject.securesettings.plugin.extra.WAKE_LOCK_TYPE-type>java.lang.String</com.intangibleobject.securesettings.plugin.extra.WAKE_LOCK_TYPE-type>
<com.twofortyfouram.locale.intent.extra.BLURB>Screen & Keyboard Lights On
1 Second</com.twofortyfouram.locale.intent.extra.BLURB>
</Vals>
</Bundle>
<Str sr="arg1" ve="3">com.intangibleobject.securesettings.plugin</Str>
<Str sr="arg2" ve="3">Secure Settings</Str>
</Action>
<Action sr="act4" ve="7">
<code>20</code>
<App sr="arg0">
<appClass>com.rideonewheel.onewheel.ui.splash.OWSplashScreen</appClass>
<appPkg>com.rideonewheel.onewheel</appPkg>
<label>Onewheel</label>
</App>
<Str sr="arg1" ve="3"/>
<Int sr="arg3" val="1"/>
</Action>
<Action sr="act5" ve="7">
<code>30</code>
<Int sr="arg1" val="5"/>
</Action>
<Action sr="act6" ve="7">
<code>15355</code>
<Bundle sr="arg0">
<Vals sr="val">
<AppPackage>com.rideonewheel.onewheel</AppPackage>
<AppPackage-type>java.lang.String</AppPackage-type>
<IsFirstAction>false</IsFirstAction>
<IsFirstAction-type>java.lang.Boolean</IsFirstAction-type>
<OnlyClickable>false</OnlyClickable>
<OnlyClickable-type>java.lang.Boolean</OnlyClickable-type>
<OnlyVisible>true</OnlyVisible>
<OnlyVisible-type>java.lang.Boolean</OnlyVisible-type>
<Regex>false</Regex>
<Regex-type>java.lang.Boolean</Regex-type>
<UIUpdateFields>com.rideonewheel.onewheel:id/ridingModeLabel=:=ds,com.rideonewheel.onewheel:id/batteryLabel=:=batt</UIUpdateFields>
<UIUpdateFields-type>java.lang.String</UIUpdateFields-type>
<UIUpdateText><null></UIUpdateText>
<UIUpdateText-type>java.lang.String</UIUpdateText-type>
<com.twofortyfouram.locale.intent.extra.BLURB>Only Visible: true
Only Clickable: false
App Package: com.rideonewheel.onewheel
Check Screen State: false
Variables: ds, batt</com.twofortyfouram.locale.intent.extra.BLURB>
<net.dinglisch.android.tasker.RELEVANT_VARIABLES><StringArray sr=""><_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES0>%aiapp
App Name
</_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES0><_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES1>%aiid()
Element Ids
</_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES1><_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES2>%aipackage
App Package Name
</_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES2><_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES3>%aitext()
Element Texts
</_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES3><_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES4>%batt
batt
batt</_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES4><_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES5>%ds
ds
ds</_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES5><_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES6>%err
Error Code
Only available if you select <b>Continue Task After Error</b> and the action ends in error</_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES6><_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES7>%errmsg
Error Message
Only available if you select <b>Continue Task After Error</b> and the action ends in error</_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES7></StringArray></net.dinglisch.android.tasker.RELEVANT_VARIABLES>
<net.dinglisch.android.tasker.extras.VARIABLE_REPLACE_KEYS>ActionTimeout AppPackage UIUpdateFields UIUpdateText FieldsToGet plugininstanceid plugintypeid </net.dinglisch.android.tasker.extras.VARIABLE_REPLACE_KEYS>
<plugininstanceid>acc94305-6a1c-443d-a0c1-e96e45235976</plugininstanceid>
<plugintypeid>com.joaomgcd.autoinput.intent.IntentUIQuery</plugintypeid>
</Vals>
</Bundle>
<Str sr="arg2" ve="3">AutoInput UI Query</Str>
<Int sr="arg3" val="20"/>
</Action>
<Action sr="act7" ve="7">
<code>548</code>
<Str sr="arg0" ve="3">%batt %ds</Str>
</Action>
<Action sr="act8" ve="7">
<code>171</code>
<Int sr="arg0" val="7425"/>
<Int sr="arg1" val="7486"/>
<lhs>%batt</lhs>
<op>0</op>
<rhs>1</rhs>
</Condition>
</ConditionList>
</Action>
<Action sr="act9" ve="7">
<code>30</code>
</Action>
</Task>
</TaskerData> -
zlyons 5 March 2016, 21:46 UTCZ
THANK YOU! I know I complained a lot, but the app works great on my LG G4. I feel a lot safer being able to monitor my battery. THANKS
dicorci 10 March 2016, 08:14 UTCD
can't believe it only works on android 5.0 and up, i waited so long, PLS FM MAKE IT BACKWARDS COMPATIBLE
J-Glide @fabuz 11 March 2016, 23:43 UTC
@fabuz That sucks man, sorry
