Downhill of the Death story
Post(s) 0-10 are missing from the archive :(
fabuz @Aaron Broward FL 12 July 2016, 10:52 UTC
@Aaron-Broward-FL you're right man, after rewatching my wipeout, i think that i push the limit too much in a big downhill and at the braking moment (ok it was a hard braking ) the board tilted forward and thrown me off...so the lack of experience on my part about downhill explain my wipeout. ...so @njcustom the nosedive is not 100% my responsability ;)
Aaron Broward FL 12 July 2016, 12:22 UTC
Sexy. Sexy.
I actually wish I would have taken the picture a day later when the cut on my hip turned into a 8 inch by 4 inch bruise and the 3 road Rashed patches began to drain fluid then turned into scabs and started bleeding. One minute I was going + 15 mph the next, my face was sliding into pavement.... Good thing I had the helmet and wrist guards. Wish I had the elbow pads.
njcustom @Aaron Broward FL 12 July 2016, 12:53 UTC
@Aaron-Broward-FL you are correct.. failure is one of 2 things.. you pushed the limits of the motor or the sensor was disengaged..
CCount 13 July 2016, 02:05 UTC
You missed one, njcustom! I have taken some good spills as a result of the battery dying... No warning, it just dies, the nose dives and digs in, and I go flying. I am working on an audible battery monitor, which will beep when the battery reached a certain voltage. The tough part will be determining what the exact voltage actually is that causes the OneWheel to turn off. I foresee a few bruises in my future!
fabuz 16 July 2016, 23:08 UTC
Downhill of the death video here(part one): https://youtu.be/baOnPgf8cbc
@njcustom sorry dude I haven't had time to edit the nosedive slowmo...
I'm waiting for all your comments about this happy ending ;) -
Dude @fabuz 16 July 2016, 23:22 UTC
@fabuz Ouch, I see Pain...
madsb @fabuz 16 July 2016, 23:25 UTC
@fabuz Wow, you were going fast! I think you hit the speed limit there 😬 Looks like a pretty steep decline too!
njcustom 16 July 2016, 23:49 UTC
Looks as if you went past the "pushback" .. I could be wrong
thegreck @fabuz 17 July 2016, 01:39 UTC
@fabuz That might be the fastest I've seen anyone ride that thing! Gnarly fall, too. Looks like you may have hit the limit then over corrected.
No 17 July 2016, 02:01 UTC
Is it possible you overcharged it? When going downhill, if you keep going when you're already at 100% power, it'll just shut off.
thegreck @No 17 July 2016, 02:22 UTC
@No He had said he was at 20%, but you have to be braking to charge down hill, and he was pushing it the whole way.
CCode-ster 17 July 2016, 05:43 UTC
@fabuz Dude, even though I knew what was coming at the end I watched the whole vid just enjoying the SPEED that you always make look effortless. Glad you're ok bro!
fabuz @njcustom 17 July 2016, 13:07 UTC
@njcustom said in Downhill of the Death story:
I think that you're right man.the problem is that when the PushBack is coming , the board tilt forward and eject me so ,this is very dangerous, I would have prefered that the board slide on his back....
To conclude, I hope that this video show to the community the limits of the board riding downhill(can't explain all my feelings about that due to the langage barrier)and for those who wants the board goes faster, they must be crazier than I am ;) -
njcustom @fabuz 17 July 2016, 13:33 UTC
@fabuz I've had mine up to 21mph lol its scary.. I try to hang my weight to the backside so if anything happens it tail slides.. breaking past pushback isnt easy.. it takes alot of practice and balance.. once you're past pushback "you're" doing most of the balancing..
CCode-ster 18 July 2016, 05:26 UTC
@njcustom I've been beyond 20mph myself, and hitting the pavement at that speed sucks! And I hit prepared, literally jumping from the board and bracing for a hard, hard impact. @fabuz obviously had no warning or time to brace for impact, and that's an unpleasant surprise that I wouldn't wish on any rider.
Iitwire @Code-ster 27 July 2016, 00:14 UTC
@Code-ster at those speeds i would want to wear motor cycle crash armor but then you don't, look as cool :)
groovyruvy @fabuz 27 July 2016, 16:13 UTC
@fabuz sick video. That downhill and your battle wounds are epic. In my opinion the board just doesn't perform as well, or as expected, once you go past pushback. Looks like you were pushing max speed, and just before the wipe you pressed the nose a bit and the board couldn't level up because past pushback you're doing most of the balancing on your own and the board loses some of its self-leveling abilities. Only way I know to get out of those situations is to lean back just a little and let the board slow to just below pushback, and then you get the full advantage of the software and the self-leveling abilities. I've also experienced something on steep downhills, I call it the death wobble. Only happened to me a couple times but I could not recover. Was booking at top speed and hit some uneven payment which caused the board to shim back-and-forth sideways, then really heavy and then I bailed. Only experienced at top speed just on the edge of pushback. So for me the optimal riding speed is just a nudge before it pushes back.
fabuz 27 July 2016, 19:50 UTC
Here is the Part.2 of my Downhill of the death:
https://www.youtube.com/watch?v=6DqsPV6Sd8k@groovyruvy I promise you that I didn't press the nose ;) I was trying to lean back like you say in your post(I was very fast)...I was very surprised how the board tilt forward and threw me off :(
@Jimmers75 @thegreck I found a little place for your shop link ;) -
thegreck @fabuz 27 July 2016, 20:29 UTC
@fabuz said in Downhill of the Death story:
Nice, thanks! Looking forward to checking out the video once I'm off work, too!
Iitwire @fabuz 27 July 2016, 21:52 UTC
@fabuz very nice vid man.
groovyruvy @fabuz 27 July 2016, 22:24 UTC
@fabuz in that case I think it's an example of the board performing unexpectedly after reaching pushback speed.
westcoastr @fabuz 28 July 2016, 04:15 UTC
@fabuz So I'm noticing that you're not wearing any extra gear after the crash... No elbow pads? I hope you've healed up; thanks for the great video! Your donkey friend was a nice touch. :)
fabuz @westcoastr 28 July 2016, 06:58 UTC
@westcoastr thanks man! I wasn't used to fall ;) and Unfortunately I'm not confortable with the pads but next time I'll do a badass ride, be sure I'll wear them!! ;)
SC720 29 July 2016, 03:22 UTC
I didnt start wearing pads or helmet til the first overconfidence wipeout. Elbow pads are probably overkill unless you plan on screaming downhill like @fabuz though.
Note for the newer folks. -
thegreck @fabuz 29 July 2016, 04:48 UTC
@fabuz Next time you bomb a hill like that, could you use a GPS tracker app and see what your top speed is? I'm curious because it looks like you're going faster than top speed in those videos.
fabuz @thegreck 29 July 2016, 07:08 UTC
@thegreck I planned(early september when kids go back to school) to do a top speed and pushback limit video for @Dude so I'll try to do that for you ;)
Dude 29 July 2016, 16:28 UTC
@fabuz Awesome my friend. I can not wait.
1woman1wheel @Aaron Broward FL 29 July 2016, 17:23 UTC
@Aaron-Broward-FL that's exactly what happened to me! Nasty isn't it? Hope you've recovered well. I have no more pain, but the road rashes left dark patches that look like birth marks. Hoping they'll fade even more with time
1woman1wheel @fabuz 29 July 2016, 19:34 UTC
@fabuz ooh that death wobble on the back foot... all too familiar with that
Ccharge360 31 July 2016, 15:12 UTC
nice video. Ton pied n'éait pas completement du la bande bleu. ca m'a arrivé aussi. Parfois il sufit d'une mauvaise vibration qui fait sauter un peu ton pied. je me tien le pied droit sur la bande maintenant et avec des soulier vraiment plat et ca ne m'a pas réarriver
