OW front sensor nosedive firmware fix
Post(s) 0-14 are missing from the archive :(
mrb 16 September 2016, 17:26 UTC
@detroitwheelin
you are right. other than 'nosedives' which are due to overweighting the nose, there is a problem with flaky 'sensors' disengaging and the subsequent 'crapout'. if you do not have flaky sensors then you may be unaware of this dangerous quality control issue.
a firmware change that would alleviate the issue of being ignored by your board, would be a longer keep-alive after no sensor contact. this creates an issue of longer unmanned driving after a case of rider error (falling).
the way the board should have been designed, and a good safety measure to prevent issues with flaky sensors is to have sensors for both feet.
Nnewtechsports 16 September 2016, 18:51 UTC
We have two boards: 3xxx and 4xxx series. The latter one has slightly longer delay (maybe 100 ms) from sensor disengage to motor disengage. No problems with either of boards and I personally like the faster 3k-series. IMO: The other way around is a lot more dangerous. If the sensor wouldn't see you falling and the board would rush into other people.
The disengage without purpose could be solved by using foot sensors on both pads.
mrb @newtechsports 16 September 2016, 19:38 UTC
@newtechsports
i agree that the board driving unmanned can be more troublesome in certain situations--like a busy intersection or next to little kid or a beehive.
consider this: would you rather have the board dive off a cliff after you safely bail out or, to slide off the cliff yourself with the board sitting there waiting for its next victim.
ZZen.Potatoes 16 September 2016, 19:53 UTC
@mrb
Has OneWheeling at the side of cliffs suddenly become a thing? :p
mrb @Zen.Potatoes 16 September 2016, 20:09 UTC
Ddalisdair 6 October 2016, 01:25 UTC
In 2010, Jimi Heselden, owner of Segway Inc., was killed when he drove over a cliff on a Segway., he was riding a path near the edge, and supposedly stopped to let a man and a dog pass, and reversed over the edge.
Ddalisdair 6 October 2016, 01:51 UTC
I'm at least 220, and I experienced regenerative pushback downhill today. I've also had it at low battery at about 4%. I've found if I go really slow I don't have the low battery pushback, so I can creep slowly at a speed where a fall wouldn't be dangerous anyway, and squeeze every bit out of the battery without pushback and stop at 1%. I ride elevated and the pushback seems very strong to me, I can't imagine trying to push through it, it feels extremely unstable when it happens and I need to get off immediately.
I leave it in elevated at all times, and have no problem with it on flat areas, for me, elevated seems safest, and least likely to nosedive. It just feels conservative, like i'm ready to brake, and less likely to goof up and have my weight too far forward.
mrb 7 October 2016, 20:22 UTC
elevated
w00t
thegreck @dalisdair 8 October 2016, 03:51 UTC
@dalisdair said in OW front sensor nosedive firmware fix:
Not sure where you heard the part about letting a man and his dog pass, but everywhere I've seen this story they've said the specifics of his death are a mystery. His body and Segway were found in a river and there were no witnesses, so there's no telling how it happened exactly. Could've just had a heart attack while riding and gone out doing what he loved.
Ddalisdair @thegreck 8 October 2016, 23:31 UTC
Wikipedia. Man with dog is cited as a witness, and the part about letting them pass was conjecture by the Coroner, hopefully based on the account of the witness.
