Beach Riding - Yes or No
Post(s) 0-5 are missing from the archive :(
thehoff 16 September 2016, 20:36 UTC
I ride on the beach every week.. best to ride at low tide in the hard packed sand.. I always hose down and scrub with a soft brush.. then hose again.. I quickly dry and stand the board on its end.. I've removed foot pads to clean underneath them a few times and all seems good..
Wwr420 16 September 2016, 20:36 UTC
I've done it also and it did not go well. I was in fresh water up to the axle and the board died 20 minutes later. Had to be sent back to replace the battery. YMMV
If you are in salt water I would rinse the board with fresh water after.
The biggest issue i saw when disassembling it after was the plugs going into the controller do not have blanks in the terminals where there are no wires allowing water to pass through a hole into the connector. -
mrb @wr420 16 September 2016, 20:39 UTC
i thought Onewheel is an amphibious vehicle. i was planning on riding it straight into the ocean and the riding it back like a surf board.
thegreck 16 September 2016, 20:46 UTC
And remember, water doesn't hurt electronics as long as there's no current running through it when it gets wet. So just be sure you turn off the unit before rinsing it with fresh water after riding through salt water, and hang it from a clothes line to dry for a day before turning it on again. Use extra strong clothes pins.
mrb 16 September 2016, 21:09 UTC
i'm gonna seal off my board and fill the tire with ammonia and ride it on the bottom of the ocean.
i never thought i would wear a helmet in a Onewheel.
SSeaP90d 27 September 2016, 21:10 UTC
I used to ride on the beach but no more, had bad nose dive fall on the way back, board locked up at speed and stayed that way. Sent in for repair and reason given was water got into control module.
Wwr420 28 September 2016, 04:54 UTC
Oh ya, YES on the beach riding..right up there with golf courses and full moons. Dip it in WD-40 and go for it!
LidPhones @wr420 28 September 2016, 06:18 UTC
@wr420 Got to love WD-40. ;-)
fabuz @BriFi 28 September 2016, 06:30 UTC
@BriFi here is my beach ride ;)
https://youtu.be/yRhWMj--zEg
Just awesome sensations ;) -
Rno 28 September 2016, 08:39 UTC
Go for it,
Start upwind then come back down wind for max speed and less juice pumped :
https://www.youtube.com/watch?v=w6DSFeTYl48Cheers
Arnaud
PS: Don't sink it though ! rince it nice and let it dry. -
DDavidJohn @Rno 28 September 2016, 10:41 UTC
Its one main reasons I bought one.. https://vimeo.com/162459999
Aahxe45 28 September 2016, 13:09 UTC
@BriFi I ride on the beach fairly often. One of my favorite rides is in cape may point, New Jersey if anyone ever gets the chance to go. It starts on off-road running/biking nature trails that zigzag parallel to the beach for about 2-3 miles depending on which trails you take and you could take ones that are 10+ miles long. Then you can take a trail that leads directly to the beach and starts you off on flat ground with lots of pebbles and slowly you begin to climb a large hard packed sand hill. Once you reach the top is when the real fun starts and you get to ride down the other side and get on to the actual beach. Like everyone else has recommended go at low tide and don't fully submerge your board in the water. I avoid the water and super wet sand as much as possible just because you get no benefit anyway going through the water so why take the chance.
westcoastr 28 September 2016, 15:23 UTC
The sand has to be right; my mistake was riding at low tide on a mucky beach. The wheel was soon caked with a thick layer and it put a lot of strain on the battery. It turned out to be less fun than I had imagined. Riding barefoot was definitely the only way to go, as flipflops were worse than useless and wouldn't stay on the board!
thegreck @Rno 28 September 2016, 15:26 UTC
@Rno Sorry, your video was too long, I couldn't sit through the whole thing ;)
MichaelW 28 September 2016, 15:30 UTC
I love beach riding but I go for low tide only and stay out of the water now. I have had two boards die on me after beach rides where my board got wet. Better to say away from the salt water. Rain is 100% ok.
thegreck @MichaelW 28 September 2016, 15:39 UTC
@MichaelW said in Beach Riding - Yes or No:
That's good to know, because winter is coming and it'll be the first time I'll be commuting to and from work on my Onewheel during the "rainy season" (which in LA usually means every now and then it might drizzle for a few minutes).
groovyruvy @thegreck 28 September 2016, 16:34 UTC
@thegreck wondering if there's an opportunity for a new product- waterproofing retrofit kit
Aahxe45 28 September 2016, 18:26 UTC
@groovyruvy I would think it would be tough to sell as a product because you would be selling silicone and some plugs maybe. You would also be telling people to open up their boards and risk some backlash if they mess it up from not knowing what they are doing.
groovyruvy @ahxe45 28 September 2016, 18:38 UTC
@ahxe45 yeah, scratch that idea
frotozoa 2 October 2016, 19:34 UTC
Beach riding? Heck no. Since spraying water on it is not an option.
I would say yes if I won the lottery, in which case I would own at least 5 of these things. and I would buy one for some schools in the area, and they could have a Onewheel club. You could have a set amount of people in each class and a ten minute limit to cruise around. Since it charges quick you could get another 10 minute ride after you wait your turn. -
hustle 3 October 2016, 13:08 UTC
I just spent a week in FL beach riding. My dad and I bought gorilla tape and taped up most of the front end, leaving the charge port and power button open so we could tape that individually and use when needed. We went through some low water here and there throughout the week and everything is fine.
Dmonicle @BriFi 3 October 2016, 17:36 UTC
It's my favorite place to ride. I hose off my board with the ports covered, so far no issues.
@BriFi said in Beach Riding - Yes or No:
Hey gang,
I frequently ride on a path along the beach and often feel tempted to ride on the wet packed sand during low tide but I don't want to risk damaging my beloved OW. Anyone have any experience with this? Any horror stories?
Enjoy the wknd!
njcustom 3 October 2016, 18:37 UTC
I rode my board directly into the ocean lol and it never turned off or anything.. it was totally submerged..
