Got my onewheel small unboxing *instagram*
Post(s) 0-21 are missing from the archive :(
s2kboy 21 April 2017, 21:07 UTC
s2kboy 21 April 2017, 21:41 UTC
Okay I put it in "squid" mode and I felt the pushback actually seems very intuitive and not super harsh but it can kick you back feeling like you are about to scrape the tail.
s2kboy 22 April 2017, 17:31 UTC
Range got a lot better after I did 4 deep cycle charges overnight after depleting it. Almost 6 miles with a lot of heavy acceleration and some hills.
s2kboy 23 April 2017, 22:29 UTC
Range seems to have gotten even better
I would def like it to have more speed tho I am pretty noobish and I can see myself getting use to 19mph real quick.
TT-CAT 24 April 2017, 00:57 UTC
Nice man!! The better speed of the + is nice in comparison to the original OneWheel. On the Original on Extreme shaping, I would get the beginning of pushback at 13.5 mph. On the + I get pushback beginning at 16-16.5mph in Mission shaping. Its also quieter at those speeds by a significant bargain, whereas my Original definitely made noticeable noise when pushing it at those limits.
I have been pushing the limits of the battery a bit more each ride and doing a full charge. I just got back from the ride starting at 100% and rode all around town (in Mission shaping) until I reached 1% battery life. The total trip was 7.9miles, assuming the OneWheel trip odometer is actually correct. If I can remember all the turns I made, etc., I'll have to see if I can use Google Earth to retrace the mileage for comparison purposes. I'm a very lightweight dude, so that probably helps with the mileage I'm experiencing too.
s2kboy @T-CAT 24 April 2017, 01:54 UTC
@T-CAT said in Got my onewheel small unboxing *instagram*:
I get anywhere between 4.5 to 6.5 miles on a charge depending where I go and how I ride.
TT-CAT 24 April 2017, 02:51 UTC
That's darn good and seems in line with Future Motions specs.
In the future, I'd love to see replaceable batteries and/or better mileage, but I'd still rather get less mileage on a device like this than a traditional electric skateboard because the fun factor and versatility of a OneWheel is amazing.
s2kboy @T-CAT 24 April 2017, 03:38 UTC
@T-CAT honestly I think the range is enough you get tired after running the battery out anyways. However more range while keeping the same weight or less would always be welcome. I would like to have more speed before push back while keeping the same range seems like a more plausible idea at this point in time. Almost seems like the board can do 21-22 mph
TT-CAT 24 April 2017, 04:06 UTC
I definitely agree about the weight. Before the range is improved and/or before swappable battery capability, I'd put lowering the weight of the board at the absolute top of my list. If it were 15 pounds or so, it would make a significant difference in portability.
bazzingapunk @Waterloo1wheeler 24 April 2017, 14:23 UTC
Going a bit off topic, but I should pump more air if I'm on the heavier side? I'm around 215LB I think. What would I notice if i change it from 20 to 22 psi? @Waterloo1wheeler
LidPhones @bazzingapunk 24 April 2017, 14:25 UTC
@bazzingapunk
I am 230+ and run 20.5 and it rides well. I get around 6 mile range. -
slydogstroh @bazzingapunk 24 April 2017, 14:28 UTC
@bazzingapunk The more air the "harder" the ground/bumps feel and you will get a little less grip when offroading, especially on loose gravel. Definitely don't be afraid to try different PSI levels to find what works. From my experience 2 psi does actually make a difference! Both in range and feel.
s2kboy @bazzingapunk 24 April 2017, 15:12 UTC
@bazzingapunk I am 190lbs and at 20 psi from factory the tire feels hard to the touch even when you press it I can feel all the bumps and cracks in the road offroading is not a problem I think I would stick with 20+ if you are anywhere close to 200lbs.
