OW+ Will Not Charge
Post(s) 0-13 are missing from the archive :(
Onewheel Miami @Joel 30 October 2017, 16:49 UTCO
@joel
Just out of curiosity - what are the temp readings on battery and controller?
Joel 30 October 2017, 22:21 UTCJ
@OW-Miami
Battery 32.0 F
Controller 69.8 FAlso when the app launches it tells me that the board is overcharged then tells me I only have 10% battery but 100% is displayed... Just now the app told me my firmware is corrupted and I need to update... updating now to version 4020... done, relaunched app and it tells me 00% power. I still can’t power up the board and power button does nothing. Now controller temp reads 73.4 F. No reply from FM yet. Bummed.
Joel 30 October 2017, 22:50 UTCJ
No luck calling support, just hangs up on you
Joel 30 October 2017, 23:27 UTCJ
Also when I plug the board in it acts like it’s on. The wheel does not move freely and it will level if I press on the sensor with my hand. It’s like the board is using the power adapter for its power source and not seeing the batteries. There is a whirring sound coming from the wheel also.
fruitygreen @Joel 31 October 2017, 01:20 UTCF
@joel Exactly same symptoms I have. Sent my board in.
I got it to charge by rolling the board as if activating regen. Somehow after that youll feel the board goes free wheel and now begins to charge.
Rreadysetawesome 31 October 2017, 02:27 UTC
This may not help you who have the problem but it happened twice to me and was able to resolve myself so I wanted to share. It felt like it got stuck in a weird mode where plugging in turns it “on” in the way the power button does, no charge/green light. I had to push the power button at least once while the board was plugged in, then disconnect the charger plug, power cycle the board again, making sure to give it some time after powering off... then reconnect the charger.
JJoel @fruitygreen 31 October 2017, 10:48 UTC
@fruitygreen
Thank you for the suggestion, I rolled it around a bit, as much as I could with the power cord attached but I only have a few feet to roll it. Did not get the board to “go free” still acts like it on. It’s like the power button does not work. -
JJoel @readysetawesome 31 October 2017, 10:51 UTC
@readysetawesome
Thank you, I have also experienced what you describe but that “fix” is not working for me this time :( -
GGadgetrider 31 October 2017, 12:52 UTC
I wonder if there is power button sequence (like holding it down for a few seconds) that causes the firmware to do a cold reboot?
The other option could be to disconnect the power from the charger AND also disconnect the battery pack. Let it sit for a few minutes then re-connect the battery pack and try charging again.
Let us know if that helps at all.
JJoel @Gadgetrider 31 October 2017, 14:43 UTC
@gadgetrider
I have tried holding the power down for a few seconds also holding it down while plugging in the power adapter and no luck. If anyone knows of a firmware “cold reboot” sequence that would be cool but not sure that would be the solution because some how that already happened to me and it did not fix the problem. I don’t know how to unplug the battery pack but would be willing to try that, it must be the nut that goes in to the rear footpad but not sure how I would get to it to disconnect the battery?
Thank you so much you guys for your help so far! -
JJoel 1 November 2017, 21:47 UTC
I got a nice email from FM today telling me to ship it back to them for service. I will update when I know more.
OOnewheel Miami @Joel 2 November 2017, 02:53 UTC
@joel
Something is deeply wrong if the battery is at 32 degrees. Clearly something is dead. Send it back to FM.
Nnicksmename 22 November 2017, 19:36 UTC
Looks like im having the same problems.
See my video
Nnicksmename 22 November 2017, 20:00 UTC
My V1 now has just started working.
Plug in. long press the on button till charger light changes. disconnect. turn back on.
See how long it lasts
Hhenrythedj 2 March 2018, 00:01 UTC
having the same issue, almost on mile 500 of my OW+. unfortunately i’m stuck at this diner by my dry cleaning place - limited space to try some of these methods. will update if anything works
Hhenrythedj @henrythedj 2 March 2018, 00:06 UTC
@henrythedj my battery is also showing 32 degrees fahrenheit- controller and motor close to 70 degrees F. rolling didn’t work
Mmarcelo 11 September 2018, 00:53 UTC
Now its my time to have such problem.. My V1 is two years old and 400 miles on it, and never had any issues, only scratches.. But three weeks ago I rode to completely empty the batteries and forgot to recharge right after getting home.. That moment I think, I killed my board. Leaving the batteries empty for too long is deffenetly not good as the electrical circuits drains electric current even when not on.
When I try to recharge, the green lights goes on and the pulsing blue light indicates the battery is full, but the app say 0%.
Well, sending the board back to FM is not an option for me.
Tryed everything as you guys suggested but with no luck.
Next step is disassembling and trying to recharge each bat cell separately..
With luck the BMS will work afterwards
