Help understanding "overcharge"
Post(s) 0-13 are missing from the archive :(
Ddjinn @ggould 27 October 2017, 21:02 UTC
@ggould: What kind of motor does the OW use? Can't we just reverse the phase sequence of the motor in order to brake?
GGadgetrider @ggould 27 October 2017, 21:08 UTC
@ggould The resistor bank with heat sink could be an interesting solution and allow the braking effect to continue well past the battery's ability to accept the current. However, the overcharge condition is pretty rare as in most cases the battery should be more than happy to accept some regen charging. Since the occurrence is so rare, FM probably accepted this as a design limitation and moved on.
The one exception that has puzzled me was a Youtube video that I saw about someone climbing up a mountainous road. It looked like it took him a long time with multiple charges to get up to the top. My question is "how did he get down"? Did he have to stop part-way down and expend that battery somehow?
Also, would it be a fair assessment that the faster I zip down a hill, the less charge I take on? Basic physics would dictate that the conversion from potential energy to kinetic energy (which converts to electrical energy) is independent of speed. However, intuition tells me that the braking effort to go down a hill slowly may create more of a charge than if I descend quickly with minimal braking effort.
Gggould @Gadgetrider 27 October 2017, 22:40 UTC
@gadgetrider The last brake chopper I worked with (on an agricultural robot) weighed five hundred pounds and needed a separate radiator to keep from melting, so my knowledge of such things has little application to the OW.
In general the OW design seems to be working near the limits of practical heat dissipation, so I am confident that FM's engineers have considered this.
skyman88 @Sam 27 October 2017, 22:41 UTC
@sam
Check out this page, tons of answers and guidance
http://onewheel.wiki/Riding_technique#Regeneration_Pushback:
Sam @skyman88 28 October 2017, 02:30 UTC
@skyman88 oh wow that's a great site! never thought to look for a onewheel wiki page, thanks for sharing
Sam @Lighten_Lens 28 October 2017, 02:33 UTC
@lighten_lens I see... I guess all we can do is ignore him and hope he gets bored and goes away. He clarified further down the thread that it was indeed meant to be a joke... but last I heard jokes were meant to be funny...
WWheelCity 28 October 2017, 12:36 UTC
My electric car does it the best - whenever it's charged to over 100%, regeneration is disabled. It's a little eerie, because the car will coast like it's in neutral for the first few miles (or, like all cars with an internal combustion engine). Then, regeneration will return.
Simon 30 October 2017, 00:02 UTC
The difference is that an electric vehicle also has friction brakes and a Onewheel does not. I usually do a few laps of the car port before descending our driveway when the battery is fully charged.
Vspot415 11 November 2017, 05:03 UTC
The Onewheel uses a the Constant Current/Constant Voltage charge technique (CCCV) its pretty common for quick charging. So what happens is when you plug into the board the charger will start giving max current which is 3.5A on this charger. Then at 80% charge the board BMS will start dropping current while maintaining 58V and finish the charge. At this point your trickle charging and the BMS won't allow the board to go above 58.4v. LiFePO4 battery chemistry is very resilient to overcharge and can safely be overcharged to 4.2v per cell. I would not worry about over current at all when it comes to damaging. However the BMS is another story and can shut down the board if it thinks it's overcharging. I'm guessing they play it safe and shut it down way earlier than necessary. Regenerative braking is just a by product of the way the Onewheel is designed. The energy has to go somewhere and it makes it's way back to the battery.
GGadgetrider @Gadgetrider 2 July 2018, 00:37 UTC
@gadgetrider Just an update - current thinking is that leaving it plugged in all the time (not a max of 48 hrs) is perfectly fine and I have been doing it during riding season without issue. I use my OW's everyday from 100% to 44% and plug in overnight. Some days if it is raining out or I don't use it, I leave it plugged in. If I go away for a week, then I may unplug it. Float on my friends...
