Hi-Tops For Foot Cramping?
Post(s) 0-41 are missing from the archive :(
Ssteak 13 August 2019, 13:28 UTC
Strong endorsement for hi-tops. The ankle support did considerably reduce cramping in the back foot and make it much easier for ever so slight but massively relieving foot adjustments.
Started out with NikeSB low-tops. Foot cushioning was great but lots of cramping and difficulty doing slight foot adjustments.
Also, some food for thought. Am finding that these boards are really made for carving, not straight line-ing. Introducing even a slight carve into my riding did a lot to reduce cramping further.
OneDan+ @steak 13 August 2019, 19:54 UTC
@steak said in Hi-Tops For Foot Cramping?:
I discovered this a couple of months into OW riding, though now I carve almost all the time . . . it's just more fun. :) Also, rolling your feet side to side every so often, even just a little, can help relieve cramping.
The Nike SB low-tops were my first attempt at using skater type shoes and they caused my feet more pain than my regular Nike Air Max shoes. I even tried adding comfort soles. I'm sure everyone is different. The Vans 112 Mid Pros work for me (amazingly well), so I think it's whatever you find that is comfortable for you when riding.
OneDan+ 22 August 2019, 16:54 UTC
I can't be the only one with this problem! Guess the back shoe :) . . . and I have a fender. This is dust from the back while riding a dirt rode about a mile.
a_onekatie @OneDan+ 22 August 2019, 20:54 UTC
@OneDan OMG that is amazing!
OneDan+ @a_onekatie 22 August 2019, 21:29 UTC
@a_onekatie They do clean up nicely tho, it's mostly just dust.
Sponge315 22 August 2019, 22:48 UTC
I haven't tried any high-tops yet. But of the shoes I have tried these are the current distance and comfort champions.
They are your everyday average Teva's. They are flat bottomed for good control but seem to have just enough squish for distance and shock absorption.
Might change my mind come winter.Others I have tried:
Nike Downshifter6 (OK)
Sketcher sketch air (worst, way to soft)
Mizuno Waverider (OK, old enough to have less squish)
Merrell (low top hikers, too much heal)
Minnetonka Moose leather mocks (OK)
$.99 walmart flip flops (broke, of course)
Barefoot (second favorite) -
a_onekatie 23 August 2019, 01:05 UTC
I actually rode in Frye engineering boots over the weekend! Had to hike a bit thru weeds and grass to get to my spot, and I didn’t want my skate shoes getting covered in stickers and foxtails. I figured it was okay since OnewheelAngel (winner of the W’s Race for the Rail) rides in cowboy boots!
a_onekatie @Sponge315 23 August 2019, 01:08 UTC
@Sponge315 You don’t crave ankle support in those?
Sponge315 23 August 2019, 02:11 UTC
Na, never had any ankle issues. But do have to usually buy a size or two large to get them wide enough.
Dang duck feet. -
skyman88 @OneDan+ 23 August 2019, 14:09 UTC
@OneDan I know this is the shoe post... but have you tried a Kush rear pad? For me that made a huge difference in my foot cramping... also you won't be able to go back to stock grip tape afterwards, so you've been warned.
a_onekatie @Sponge315 23 August 2019, 15:29 UTC
@Sponge315 oh, lol that’s not what I meant. I’ve not had ankle issues either, but have found that adding ankle support thru hi tops actually helps to alleviate foot cramping and fatigue.
a_onekatie 23 August 2019, 16:39 UTC
Not Hi tops, but these new releases look very interesting:
https://www.vans.com/article_detail/ave.html -
OneDan+ @skyman88 23 August 2019, 17:39 UTC
@skyman88 Actually, I just installed a FM Surestance Pro Fusion rear pad and it's made a big difference. Did a 15 mile ride this morning and between the new grippy/beveled pad and the mid top Van's, I'm good to go! Tho, honestly, I've never had an issue losing grip on either of my boards, but then I only ride pavement and relatively smooth dirt/gravel paths.
skyman88 @OneDan+ 23 August 2019, 19:03 UTC
@OneDan yeah it's when you go over large tree roots you thank your lucky stars you have your feet on the board still, haha.
The Kush pad is like that also... but made of a slightly flexible polymer. So it would be good even if it was flat but that softness with the concave is just right!
Happy sidewalk surfing.
Paris 30 August 2019, 23:55 UTC
I bought a pair of Vans Sk8-Hi a year ago. I chose the Pro ones because they seemed more "skaty" than the regular skate ones.
That was a great choice. They're so comfortable. It's like riding with bootee.
A few months later, I bought the regular ones to see the difference: I will never ride with them. Never. I could be barefooted it would be the same. Regulars are garbage. Even laces are bad.
