Onewheel Pint | Pushback
Post(s) 0-17 are missing from the archive :(
EEthan_Sonberg 21 September 2019, 00:43 UTC
Yeah its been a month since I had my Onewheel+ and I've only had one push back. It wasn't really bad, have any of the New Pint Owners noticed push back?
a_onekatie @Ethan_Sonberg 21 September 2019, 00:48 UTC
@Ethan_Sonberg umm yes. That’s what this thread is about 😆
McFloaty 21 September 2019, 01:01 UTCM
15 days in on a Pint, 308 miles, and I now feel qualified to speak about pushback. Yes there is pushback that comes on relatively gently at 14.5 mph or above, dependent upon road and riding style. I say “relatively gently” and “dependent upon road and riding style” cause I think pushback aggressiveness is related to how much you’re asking of the board. Feels like when sneaking up to higher speeds gently, the pushback comes on gently. Conversely when punching it at speed the pushback can come on really aggressively and give you a Captain Morgan moment. No speed demon tho- have hit 15.5 mph a few times, but never on purpose. Float on
McFloaty @McFloaty 21 September 2019, 01:03 UTCM
@McFloaty PS- been riding skyline, 180 lbs.
MEEfO 21 September 2019, 21:13 UTCM
Got to admit I’m pretty frustrated. On day 2 with the Pint, have tried all four preset modes and nothing fixes my constant pushback issues. I hit pushback every single ride. Every ride. App shows my top speed at only 13.8 mph. I got tossed hard and took a bit of a beating nosediving after pushback. At only 13.8 mph. It’s barely fast enough to feel comfortable carving. No idea how to prevent this. Everyone else seems to be getting ~15 to 16 mph before pushback is noticeable.
Mark Vlogs @MEEfO 21 September 2019, 21:23 UTC
@MEEfO From what I’ve read pushback on the Pint starts at about 14.4 MPH
OneDan+ @MEEfO 21 September 2019, 21:33 UTC
@MEEfO Several things affect pushback, but probably the one that does the most is rider weight. Heavier riders will tax the motor sooner, so it will pushback sooner. Many who can go faster are on the lighter side. If you don't think that's it, perhaps there is an issue with your board.
a_onekatie @MEEfO 21 September 2019, 21:37 UTC
@MEEfO I only feel pushback at over 14 mph in all modes except Redwood which is set to give it at 12 mph. And in Pacific, I’ve gotten up to 15 without ever coming close to nose diving.
How aggressively are you accelerating? That and rider wt. seem to be a big factor in Pushback. Could you be unintentionally leaning too hard on the nose, as part of your learning curve? The “click” moment for me as a OW noob was when I learned to just let go and let the board do its thing instead of trying to control it, if that makes sense to anyone else? Also I don’t totally understand what you mean about not being able to get fast enough to carve? I often carve to remind myself to slow down and keep myself from going too fast.
Another thing, have you confirmed if your Bluetooth is working properly and maintaining a constant connection while you ride? Because mine does not, and if I were in your situation I wouldn’t trust for a second that the app was indeed showing my correct top speed. Mine currently does not.
If you really feel that something isn’t right with how the board is functioning, then it may be worth contacting FM as I know a few faulty footpad sensors on the pint have already made there way out into the world.
MEEfO @a_onekatie 21 September 2019, 22:12 UTCM
@a_onekatie Appreciate the detailed reply. I think everything you said makes sense. I’m 6’3” ~205lb so maybe heavier than most riders and taxing the motor? I’ll keep that in mind. I’ve never noticed Bluetooth issues with my phone before but I’ll pay more attention to it to see if it’s constantly updating stats. Re: carving I personally find it more comfortable riding/ carving at higher speeds. I guess it’s the snowboarder in me. The slower I’m going the less control I feel on the board and a bit of wobble creeps in. I’m going back out tonight and tomorrow. Hoping I get more accustomed to the pushback. Maybe I should get an XR instead if things don’t improve.
a_onekatie @MEEfO 21 September 2019, 22:20 UTC
@MEEfO said in Onewheel Pint | Pushback:
Okay I can def help you out there! Have you checked out your tire pressure yet? For optimal stability you really want it set to 10% of your body wt. FM typically, but not always, ships them at around 20 PSI, so it’s worth checking to see where yours is at. My ride felt super squirrely until I made this correction and once I did OMG the difference was immediately noticeable!
Franko @a_onekatie 22 September 2019, 00:50 UTC
@a_onekatie said in Onewheel Pint | Pushback:
For optimal stability you really want it set to 20% of your body wt. FM typically, but not always, ships them at around 20 PSI, so it’s worth checking to see where yours is at.
wait, really? there is no way i would inflate my tire to 20% of my weight. that would mean it would need to be inflated to around 29 PSI. i think that would pop it! right now i'm aiming for just under the 20 PSI it shipped with -- usually around 15-17 PSI. a softer tire really feels more forgiving to me.
OneDan+ @Franko 22 September 2019, 03:01 UTC
@Franko said in Onewheel Pint | Pushback:
@a_onekatie meant 10%, that's the advice I had given her and that many follow . . . probably just a typo ;)
a_onekatie @OneDan+ 22 September 2019, 15:52 UTC
@OneDan @Franko
Crap yes sorry its 10%! I’ll edit my other post!
Franko @a_onekatie 22 September 2019, 18:09 UTC
omg, thank you -- that makes much more sense! haha
MEEfO @a_onekatie 22 September 2019, 19:28 UTCM
@a_onekatie You’re awesome thanks for the tip! I was thinking of fiddling with the pressure. 10% that’s great to know!
MEEfO @OneDan+ 22 September 2019, 19:30 UTCM
@OneDan Thanks so much for helping out the noobs! Going to make this tweak today. Looking forward to it.
a_onekatie @MEEfO 22 September 2019, 22:26 UTC
@MEEfO NP! And yeah @OneDan is awesome!
mnk @MEEfO 25 September 2019, 01:54 UTCM
@MEEfO I experienced the same, nose dive at 14mph but earlier I ran at 20.5mph with no problem.. I think a lot of factors are involved when the board determine when to trigger the pushback. Wind in the face trigger the pushback earlier than backward.
take care
RonZon @mnk 26 September 2019, 03:55 UTC
I would guess that it senses the amount of current being drawn to power the motor.... basically the harder it is working, the more power it takes. They most likely pushback at a safe point before the motor just couldn't handle the load.
siscreens 19 July 2020, 20:43 UTCS
I cant stand the pint with the immediate push back! Selling it. XR only. They have to fix this.
Franko @siscreens 19 July 2020, 22:55 UTC
@siscreens ...why fix what isn't broken?
