EL wire modification. No glue
MCAone 31 March 2016, 14:53 UTC
Routered foot pads to accept and hold EL wire. Modified GoPro mount to hold battery case.
Dude 1 April 2016, 01:45 UTC
looks good. I was thinking about this mod, still am. I like the routed inset look.
MCAone 1 April 2016, 12:40 UTC
Thank you
I do like the clean look of not seeing the battery case but it is used at night and not an issue for me.. I didn't want anything totally permanent like glue on the board and use the GoPro mount for other mods too.
The notch in the foot pads works perfect when it is slightly less than the diameter of the wire so the screws squeeze it in place. You can also cut the excess EL wire, just be sure to cap the end.
