POPPING SOUND- Heel/Toe or Switching Directions
818 3 August 2015, 00:06 UTC
Anyone hear a popping sounds when you switch directions or your moving from heal to toe, vice versa?
I discovered this isn't normal after testing out they guys boards at yesterday's meet.
I'm not sure if the short clip got uploaded successfully, someone let me know.
[IMG_0987.mp4](uploading 100%)
DocBlock 3 August 2015, 00:07 UTC
Can't open it
MichaelW 3 August 2015, 00:12 UTC
Its all that riding in skate bowls and second hand smoke. @818
818 3 August 2015, 00:14 UTC
https://instagram.com/p/4dUiTXiITx/
You can hear it in this older clip on IG, right before and after the slow motion part.
Franky 3 August 2015, 02:39 UTC
Sounds like a defect.
Aadubberley 3 August 2015, 02:43 UTC
My board started doing that a couple of months ago. So far, it hasn't broken down or affected anything, as far as I can tell. Does worry me a bit, though.
818 @adubberley 3 August 2015, 05:37 UTC
@adubberley agreed, just worried it's a bearing or something that wearing down.
veryous 3 August 2015, 17:15 UTC
I just heard something weird/similar for the first time last night. Not sure if it's a permanent thing or some trash stuck in there. I'll keep an eye on it tonight to see if it sounds the same.
Edit: Always my biggest fear I have to send the board back somehow and go without it for a week. Not sure what I'd do then.
DocBlock 3 August 2015, 20:15 UTC
It was totally worth me upgrading to overnight shipping to only have the board out of my hands for 48 hours. They are awesome about arranging that and getting it right back to you
germx 3 August 2015, 20:38 UTC
Mine has been doing that for as long as I can remember. But not every turn, more like... rarely if maybe I turn really hard. I don't know, but I've heard/felt it a few times.
Rrev.cresci 3 August 2015, 22:07 UTC
Is the wheel shifting side to side, there is a tiny bit of play between the bearing and the snapring on the axel (non-wire side) It probably wont affect operation but mine has done it since new and is super annoying, going to throw a second snapring or thin shim in there come time for a tire change.
Zzandax 4 August 2015, 20:12 UTC
My board has always done that
BradK 16 August 2015, 03:56 UTC
I don't think it's anything to worry about mine does the same thing when taking a quick abrupt sharp turn back and fourth. and sounds like a knocking from the brackets/bearings or whatever it is that hold the tire or motor in place.
BradK 16 August 2015, 03:59 UTC
The wheel probably has to have some play like that otherwise if it where to tight against the brackets the Onewheel would more than likely rub somewhere and cause more problems.
J-Glide 16 August 2015, 10:58 UTC
Julian mentioned that something like this could happen if the bolts on the side of the rails going to the wheel aren't really tight.
SC720 28 November 2015, 21:39 UTC
Old thread but my board just started making this same noise yesterday. Any of you guys that had this months ago ever come across any other problems? any solutions? It works fine but its annoying!
CCode-ster 29 November 2015, 01:57 UTC
I haven't seen this thread before now, but my board does this as well. Feels like there might be just a little play in the side to side wheel movement along the axis. I've checked all my bolts and they seem snug so I'm not too worried yet. It doesn't effect my rides at all. It does detract from a seamlessly smooth riding "experience" though.
MichaelW 29 November 2015, 04:09 UTC
One of my boards makes this sound and I talked to OW about it. I will send them another note about it and get back to the thread to let you know how it turns out.
SC720 @Code-ster 29 November 2015, 06:01 UTC
@Code-ster @MichaelW So this is supposedly only related to the tightness of these bolts? I dont think Ive seen anyone even mention touching those. The sound does seem to be originating from that area. This happened to me after replacing the foot pads and wonder if over/under tightening of those little screws could possible change the amount of pressure on those bolts and the dynamics of the frame. It really is an unfortunate sound compared with how it was before - at least the board works but what good is carving when it comes with this awful noise.
Code-ster @SC720 29 November 2015, 07:10 UTCC
@SC720 I don't hear it all the time, or maybe I don't notice it much as I'm focused on other aspects of the ride. I just know that I have taken note of it on rather slow turns and I wondered at the time if it was normal.
cr4p 16 January 2016, 16:01 UTC
has anyone solved this issue?
Willy @MichaelW 16 January 2016, 16:50 UTC
Awesome! Looks like its solved by sending it in. Not a big deal. @SC720
SC720 @cr4p 16 January 2016, 17:31 UTC
@cr4p I emailed them and was emailed back a prepaid UPS label. Sent the board in and had it back real soon...good as new.
bsulla 18 January 2016, 23:33 UTC
In the linked post below someone mentioned the LEDs were the source of the sound. Based on the symptoms at the start of this post maybe the problem is when the LED changes based on direction. Just a thought.
http://community.rideonewheel.com/topic/912/won-t-charge-popping-sound-in-back/2
