Why does the board have to lock up @ max speed?
OriginalEric 10 June 2016, 23:44 UTC
I'm not an engineer or mechanic, so I'd love to get some feedback from you all... I know there are some rocket surgeons amongst us that could shed some light on it for me.
Last weekend, I had my first hard fall on the OW. Thankfully, I seem to have come away with no major injuries save a bruised ego, ripped shirt, bruised/sprained wrist and a nice chunk missing from my left palm (aka my mistress).
For me, the accident happened as I was riding down the sidewalk. A bike rider, also on that sidewalk (=/) was coming towards me so I dipped off the sidewalk on to the road and in that transition, with my eyes on the road ahead (cross traffic) and the bike rider, I didn't see a small pot hole in the road. I took the pot hole at speed (10mph +/-) and it threw me off balance. I had to lean forward to regain my balance, and in doing so, quickly pegged the speed on the OW causing it to stop and send me tumbling forward.
I tried to run it out but that wasn't happening... I braced with my palm, then forearm, then tucked and rolled a bit over my left shoulder and came to a stop. I had a helmet on but I rolled gracefully enough that it didn't touch the ground. My palm got the worst of it, with a little road rash on my forearm and a little less on the back of my shoulder.
The thing is... if the OW didn't hard stop when you peg the speed... if it simply cut out and coasted... I'd have regained my balance and kept on trucking. The fact that exceeding the top speed causes a hard stop is what caused me to go tumbling. Hindsight being 20/20, I should have been wearing wrist guards... I purchased some earlier in the week and they arrived yesterday... I'm thankful I didn't go tumbling in front of a car and that I am strong/agile/lucky enough that I didn't break my arm or wrist. My hand hurts and I've been mostly useless in the gym this week but all things considered I'm grateful.
Is it/would it be feasible to have a mechanism that allowed for coasting when the motor cuts out? Is there a mechanical/engineering/cost reason that would make that solution unrealistic? talk amongst yourselves =) and thanks in advance for reading/responding.
Have a terrific weekend all.
thegreck @OriginalEric 11 June 2016, 00:20 UTC
@OriginalEric Couldn't tell you, but I agree that it seems wrong.
Aaron Broward FL 11 June 2016, 00:37 UTC
It feels wrong too
Dude 11 June 2016, 00:43 UTC
I agree with everyone so far. This is a great question i would like them to answer as well.
wheeler 11 June 2016, 00:53 UTC
I have launched at over 15 mph at least 5 times the first two weeks I got it. Heres my theory or anatomy of a crash. When it takes off it gets to the speed where you start to wobble causing your foot to lose contact with the sensor which shuts the motor off which makes the nose tip forward with your weight and contacts the ground skidding as you fly like Superman towards the pavement. The key is to stay centered and don't lean forward. Get in the habit of leaning back slightly and use your ankle like on an accelerator and gently push to speed up. I am comfortable at just under 12 mph using this method. I use a biking app on my windows phone that shows top speed and map tracking. I use the elbow pads that protect a portion of your forearm too.
Aaron Broward FL 11 June 2016, 06:31 UTC
No, I just did it for the first tjme, what it is is you guys are pushing through the pushback. I was trying to test the speed of the device. I was being an idiot. And I knew the limits, I was trying to push it. I was in fact had my center of mass behind the wheel, but was pushing down to see if I could squeeze just a little more speed, then boom, it locked up and it launched me. But, the board was clearly telling me to slow down.... The people that keep getting launched, are not listening to the board.... Your just pushing forward. :). I ended up with some nasty road rash :)
Ggratefulwheel @Aaron Broward FL 11 June 2016, 08:53 UTC
@Aaron-Broward-FL
Sounds awesome. The safety feature that doubles as an anti-safety feature. -
madsb 11 June 2016, 11:17 UTC
Okay, my 2 cents:
First of all, I don't think you would be able to coast at all, even if the wheel didn't lock up when cutting out. Just try to keep your balance on the board when it isn't turned on; it's almost impossible.
Second, the reason I think the wheel "locks up" is because of the regenerative breaking, which makes the friction on the wheel super-high when the engine cuts out.
Does that make sense?
cr4p 11 June 2016, 14:56 UTC
I might be wrong, but for me it seems that it is already possible to deal with an high speed cut-of from the motor. at different occasions i managed to "recover" to regular riding again by just manually rebalancing the onewheel instead of jumping off and running it out.
e.g. when close to top speed and pushing to much on the front sensor side (because of hilarity or because of an unexpected road hole) it happend to me several times that the board stopped balancing for a moment. but if I managed to quickly react correctly and counter-balanced it, it seems like it rebalanced and I was able to continue the ride.
I even had it two times that I was already sliding on the front bumper pad for several meters at (more than) top speed, but was able to rebalance it until the onewheel rebalanced and continued to work fine.
is it just my impression, or have some of you experienced the same thing?
if so, all we need is some good practise and to stay cool instead of jumping of and running it out...altough it is risky of course;-) -
sonny123 @cr4p 11 June 2016, 15:57 UTC
@cr4p
Happened to me once when I pushed it a little and was able to recover.
I don't think it locks at top speed.
I think it locks at a steep angle which you wouldn't be able to recover from anyway.
Try it in hand. When it tilts to certain point, it locks. -
Aaron Broward FL 11 June 2016, 19:41 UTC
You guys are not taking about the same thing, I have hit a bump, had the back of the board bottom out, and I was able to rebalance. What we are talking about is... Flying along at top speed at a constant rate not accelerating... And then without warning, like getting side swiped by a bus your face is in the pavement about 10 feet in front of the board. There is NO opportunity to correct anything. It's the equivilient of what you could imagine driving into a 1 foot high concrete wall at top speed would be like, but, with no warning. :)
And, there was a comment that made sense, above, the board may not be locking up at all, the engine may just simply be cutting out, if the board is dying and there is no self balancing happening, the forward momentum of the board would carry you into a face plant.... So, that is clearly what is happening.. Because it would make no sense to design a lock up. So what is happening is if you push past the pushback, the board dies and your momentum carries you forward the board nosedives immediately, just basic physics there, it feels like someone hit the breaks, but that's the self balancing gone bye bye..
By Joe I think we got it. :)
TT-CAT 11 June 2016, 20:28 UTC
One aspect I'll bring up is that I don't think the board should be able to completely seize when the sensor pads experience a disengagement of pressure while moving. I think the board should remain active and provide a gradual deceleration of the device rather than the complete stop of the wheel rotation on pad disengagement while in motion. When I turn on the board, and don't have pressure on the foot pad, the wheel is very hard to turn, but I can imagine that accidentally having a foot slip off and have the boards wheel stop immediately can't do the rider any good. Maybe there is a way to have the board decelerate slowly for a given time period until while remaining the balance assistance or at least until pressure is put back on the sensor. Then again, this idea would have to only be put into effect while riding above a certain speed because if it was active all the time, it would be very difficult to get on the board and begin riding from a stand still.
bmtka @T-CAT 11 June 2016, 20:38 UTC
@T-CAT When the board is moving you actually have to lose contact with one of the sensors for quite a few seconds before it cuts out. (edit: by "quite a few" I mean 3 or 4.)
TT-CAT 11 June 2016, 20:44 UTC
That is true, but the boards wheel still immediately stops instead of gradually decelerating and balancing. This can be a safety concern if the both pads were to fail (or the associated electronics), or someone's foot is off the pads for just a tad too long, as the rider would go flying superman style. A gradual deceleration while providing balancing assistance would likely be the safest bet, along with having slightly wider foot pad sensors. Having four sensor pads (especially two strips of the ones on there now), but positioned horizontally instead of vertically may work. So, take the blue area now with the sensor pad (two) and lay that horizontal on the top portion of the wood plank, and another strip (of two) and place that on the bottom part of the wood foot plank. :)
wheeler 11 June 2016, 21:12 UTC
I wish the sensors could be angled. Like the bindings on a snowboard. Riding goofy and turning right is slightly awkward.
I think they designed it this way for ease of dismount. I peel my foot and sometimes start drifting back and then remount it and just jump off with both feet anyway most times. -
Jjuts @wheeler 12 June 2016, 00:38 UTC
@wheeler really? I find it a breeze turning right while riding goofy
donny h @wheeler 12 June 2016, 02:55 UTC
@wheeler good call on the idea of an angled sensor pad. I always think that too. I ride very duck footed. I guess they would have to angle them backwards for me because I'm goofy foot though.
donny h 12 June 2016, 03:01 UTC
has anyone else noticed that it can freewheel? my wife and I have both disengaged the sensors a bit too early when coming to a stop and had the board freewheel out from under us and bam, right on our backs. we have both only made that mistake once! also I want to add to the conversation that I have accelerated too fast and went through pushback twice and just ran it out and once I think that I broke contact by squirming my foot around and I got launched with no possibility of running it out so I think that the responses are different.
SSeaP90d 13 June 2016, 18:53 UTC
The only thing that makes logical sense is they gotta be working on the lock up problem, but its something with the hardware like a cut-off of some kind with the DC motor that's supplied by others and thus can't just be tweaked with a few lines of code. It really seems to be the main thing holding these boards back from mass acceptance and unequivocal endorsement by current riders, I suspect its only a matter of time before we see a motor upgrade that definitively resolves this issue.
Ggratefulwheel 14 June 2016, 01:20 UTC
I noticed mine cutting out when I attempted to go over a curb a couple times. I was going too slow so the back of the board hit the curb as I was going off the curb but my feet didn't come off the sensor so I'm confused why It cut out.
Post(s) 20-56 are missing from the archive :(
sonny123 @thegreck 21 June 2016, 19:32 UTC
Hey, thanks again.
I called a place in Colorado and they had had the color I'm looking for. Cyan matte.
He'll change the padding to fit my noggin. ;) -
thegreck @sonny123 21 June 2016, 19:41 UTC
@sonny123 Nice! Happy to help. I had been wearing a Triple-8 Gotham helmet, which is a pretty good helmet too, but switched to the S1 after I saw it and read up on it. I really liked the fit, and the fact that it was also one of the better helmets out there made it a win/win.
Dude @Electric Slide 21 June 2016, 21:06 UTC
@Electric-Slide Is the Firm ware updated on his older boards? Im curious if this could be part of the issue.
duc809 @thegreck 21 June 2016, 21:16 UTC
@thegreck said in Why does the board have to lock up @ max speed?:
@sonny123 Definitely good to have protection, but I noticed in your link that it's a non-certified helmet, which means you can't be sure if it's going to protect you when you need it to.
The S-One Lifer (which I learned about from @MichaelW ) are great helmets, and they're CPSC Certified to help protect against high impacts and ASTM Certified to help protect against multiple lower impacts: http://s1helmets.com
The S1 looks nice and very slim too! I just bought a Gotham. Dang.
thegreck @duc809 21 June 2016, 21:19 UTC
@duc809 If there's no scratches or dings (or stickers) on it, you can probably still return it. But Gotham is a good helmet... I just thought it looked a bit too big.
duc809 @thegreck 21 June 2016, 21:36 UTC
@thegreck Agreed! Gotham looks huge. I have quite a few miles on it already, oh well.
sonny123 21 June 2016, 21:38 UTC
I like that the S1 all come in one size and only change the paddings.
I have another huge helmet that I dislike the size.
here's where I got it from with free shipping.http://www.sk8ratz.com/s-one-helmets-s1-lifer-certified-multiple-impact-cyan-matte-s-one/
thegreck @sonny123 21 June 2016, 21:56 UTC
@sonny123 There are actually 3 different size helmets, then the pads make it fit more precisely. This is from their site:
If your head is between
18.5″- 20.5″ you will want an S1 Mini Lifer Helmet.
21″ – 23.5″ you will want an S1 Lifer Helmet.
23″ – 25.5″ you will want an S1 Mega Lifer Helmet. -
sonny123 @thegreck 21 June 2016, 21:59 UTC
Good catch.
By their chart, I should go with mega.
But I think the middle size might cover me since I'm 23.5.
We'll see. ;) -
Kkelp @kwatts 21 June 2016, 22:02 UTC
@kwatts i'm sure its been asked but i hadn't seen it. is there an iOS version?
thegreck @sonny123 21 June 2016, 22:03 UTC
@sonny123 Totally, I'd shoot for the smaller one first, too, and see if it works for you.
1woman1wheel 21 June 2016, 23:46 UTC
I'm not sure if this is what happened to me, cause I hit my head pretty hard when I fell and actually can't describe what happened in great detail. I felt a wobble in my back foot and tried to slow down.
The helmet definitely saved me. My boyfriend says I might need to replace it after crashing; does anyone know if that's right?
Edit: it was my snowboarding helmet, not a bike or motorcycle helmet, if that makes a difference.
sonny123 @1woman1wheel 22 June 2016, 00:24 UTC
@1woman1wheel
probably not, but why not be safe and do it.
Will be well worth it. ;) -
Electric Slide @Dude 22 June 2016, 05:25 UTC
@Dude the older boards have not been updated. They have the old firmware. But the older boards aren't the issue. It's the newer boards with the newer firmware that are slower and less stable at high speed
Electric Slide @badcheese 22 June 2016, 05:35 UTC
@badcheese That's crazy! I have the same firmware and my board drops the nose and cuts out at about 15 mph and it's about all I can do to recover without wiping out. I approach the speed very cautiously and gradually and it just cuts out on me.
parrothd @Electric Slide 22 June 2016, 14:42 UTC
@Electric-Slide said in Why does the board have to lock up @ max speed?:
I think your confused, it's very easy to push to far after pushing thru the push back. You have to fight thru the push back, once your past it the board returns to normal but you have to compensate for the lack push back or else you nose down..
Kkwatts @kelp 22 June 2016, 15:09 UTC
@kelp i wish i could, i'm just not that strong of an iOS app developer. if anyone wants to write one for iOS i'll pass along the code/details to talk to the OW. interestingly enough i've got requests for information from someone writing an app for the windows phone and sailfish OS (which i've never heard off until then).
Kkwatts @thegreck 22 June 2016, 15:11 UTC
@thegreck yeah and @bmtka convinced me that i need to wear a helmet... and i have this fancy snowboarding one with the outdoor tech bluetooth chips.
Kkwatts @1woman1wheel 22 June 2016, 21:40 UTC
@1woman1wheel if there are any dents or foam crush you are supposed to replace the helmet - they lose the ability to absorb future impacts.
1woman1wheel @kwatts 22 June 2016, 23:22 UTC
@kwatts I don't see the foam being crushed but I've read that you can't always see the damage and you should just replace it no matter what. Sounds like that could get expensive...
Post(s) 77-79 are missing from the archive :(
