replacing tire
roachman 30 January 2017, 21:12 UTC
My one wheel is almost 1 year old and I just noticed my tire is very worn where you can see threads. is that as long as a tire last? am I able to take somewhere in Houston to have changed or do I have to send into OW? thanks
Pete
floaton @roachman 30 January 2017, 22:02 UTC
@roachman
This is from a previous post by @sonny123 . I'm sure someone from this forum will guide you about Houston area. You could always just ship it to @sonny123, :)
Tire removal
https://www.youtube.com/watch?v=euqGyf_DFT8&t=1s
Tire assembly
https://www.youtube.com/watch?v=KQopEPG2SHs&t=6s
There's also Instruction thread in tech section by @njcustom
https://archive.owforum.co.uk/topic/3590/tire-change-here-is-the-tutorial/57
thegreck @roachman 31 January 2017, 15:07 UTC
@roachman You should read this post because some of the advice might apply to you as well:
https://archive.owforum.co.uk/topic/6497/tire-treadwear -
roachman 31 January 2017, 15:59 UTC
thanks. my PSI is probably a little low at 16, so that might be what caused it. I am just surprised it wore so quickly.
thegreck 31 January 2017, 16:19 UTC
@roachman That part of a go-kart tire isn't meant to ever touch asphalt, so the fact they lasted a year actually seems pretty good. If you drove your car on a near-flat tire, you'd see the same result long before a year was up.
Maybe someday Future Motion will have a tire designed specifically for the Onewheel and it'll be a bit more curved and have more protection on it for people who prefer riding with lower psi.
dalisdair @roachman 31 January 2017, 20:56 UTCD
@roachman
What is the mileage on it?
