One side feels like it hangs too low
LLarklen 28 February 2017, 16:00 UTC
Anyone ever find one side will hang lower than the other while using it? For example, right now I ride goofy (right foot forward, power switch side up) and I ride in elevated mode and it works for me, but I find Extreme hangs way too low (I feel like the front will hit the ground, thats how low).
So the other day I turned the OneWheel around so the otherside would face forward and Elevated was way to high for me and Extreme felt like what Elevated felt on the other side (not too high, just the right amount).
Month back when I was still learning, I had a fall and the front of the board (power switch side) hit a concrete block and is a bit damaged (bumper is pushed back a bit covering some LED's).
Could this have caused the issue with that side hanging lower than what it should or is there something I should try?
Picture of front of board:
sonny123 28 February 2017, 17:00 UTC
For a while I rode elevated but then decided to go back to extreme and stick with it.
After I got used to elevated, extreme felt a bit low on front but eventually felt normal again.
Stay with extreme with sensor pad on front and allow it couple days and see if it goes back to normal. -
jordo 28 February 2017, 17:24 UTC
@Larklen everything you say is true, check this out...
https://archive.owforum.co.uk/topic/3364/let-s-get-elevated
@sonny123 is right too, I doubt there's anything is wrong with your board, just perception from riding elevated.
LLarklen @jordo 28 February 2017, 17:44 UTC
@jordo Thanks for the link! You guys are probably correct, just used to riding higher so when it dips in Extreme mode, feels like it'll scrape.
I think I will probably stick with Elevated as the roads/sidewalks in my city aren't the smoothest so lots of lips that stick up an inch or so that I don't want to ever catch (again!) :P
tonyrumans 28 February 2017, 17:55 UTC
Judging by the topic title I really thought this was going to be a discussion about balls
thegreck @tonyrumans 28 February 2017, 21:28 UTC
@tonyrumans https://youtu.be/Gig-5Btyutk
tonyrumans @thegreck 28 February 2017, 21:34 UTC
sonny123 28 February 2017, 21:54 UTC
tonyrumans @sonny123 28 February 2017, 21:57 UTC
Earthpilot 1 March 2017, 02:40 UTC
Ahh ha haha, from thegreck down, love me some Glenn Gary too and I found another series to watch on my firestick, thanks tony. I was thinking the same thing when i read the title, sorry about your deck Larklen, keep riding...
This post needs music https://www.youtube.com/watch?v=a-c8bv7e6EI
MichaelW 1 March 2017, 02:57 UTC
Apio 1 March 2017, 13:46 UTC
Hubbitron 1 March 2017, 14:56 UTC
