Corner scraping
Sshaka wheeler 26 March 2017, 21:34 UTC
I turn tightly, and wear through the corners of the bumpers quick. This leads to me shaving the metal corners of the frame. Is there any way to stop this? 60 for bumpers w/ shipping is a lot, plus it still waiting on a pair.
groovyruvy @shaka wheeler 26 March 2017, 23:22 UTC
@shaka-wheeler I try and take turns just a little looser so I'm not getting that corner shaved off. Found it to be only a slight adjustment.
No @shaka wheeler 27 March 2017, 00:16 UTC
@shaka-wheeler You can try to pivot the board with your body more
Sshaka wheeler @groovyruvy 27 March 2017, 00:19 UTC
@groovyruvy Good point. Adjust myself, not the board
Sshaka wheeler @No 27 March 2017, 00:20 UTC
@No Good idea - spin turns. I'll work on those
BBgrave 27 March 2017, 01:30 UTC
Maybe don't turn so sharp?
mekon 27 March 2017, 17:06 UTC
Eh, my fenders look like I took a cheese grater to them and the corners of the frame are chowder. I just think of it as character.
¯\_(ツ)_/¯
DDa Aviator 27 March 2017, 17:26 UTC
These boards are built for it. I should be fine. Unless your trying to keep your board looking brand new for life but its not gone happen. But spin turns help a lot like someone stated and also adjusting your turn helps too. But the scraping will happen. Maybe make some type of bumper so it wouldn't scrape
Sshaka wheeler @Da Aviator 28 March 2017, 22:29 UTC
@Da-Aviator I'm just concerned taking metal off the corners of the actual frame may cause some bigger issues with the strength
GlueBreath 30 March 2017, 17:09 UTC
@shaka-wheeler I've had this issue but not because of turns.. it happens from the occasional tail slide from stopping too fast especially on inclines for me.. always recover but it has happened enough that it's shaved off a bit of the corners where the bumper meets the frame.
DDa Aviator @shaka wheeler 30 March 2017, 21:57 UTC
@shaka-wheeler i ride my onewheel pretty hard and i scrape it hard no issues ever. I wouldnt worry about it
snwbrdwndsrf 31 March 2017, 10:04 UTC
Are you talking about tight turns on pavement at low speeds? If so I have found that I can avoid most scraping if I'm a bit less aggressive and give the board some time to figure out what I'm trying to do.
I've also wondered if I could rebuild the bumper corners with something like hot glue gun glue (or maybe a harder material like some epoxy or Bondo). Or 3-D print a bumper with replaceable corner units! 🤣
Ttimvdp 2 April 2017, 01:42 UTC
maybe this can help:
https://www.youtube.com/watch?v=0e03FieE6g8 -
Sshaka wheeler @snwbrdwndsrf 5 April 2017, 01:31 UTC
@snwbrdwndsrf said in Corner scraping:
Yes- it's at low speeds. I've tried avoiding that. The issue is whenever i need to jump off the board, the bumpers really get shaved fast. I wish they made an aluminum bumper or something tougher. Or maybe a bumper with bearings installed to roll when the board comes in contact with the ground
snwbrdwndsrf @shaka wheeler 5 April 2017, 10:17 UTC
@shaka-wheeler get some epoxy putty to rebuild the corners that have worn away (the bumpers, not the aluminum). Once cured (like 20 minutes) it should last a long time.
Sshaka wheeler @snwbrdwndsrf 5 April 2017, 15:23 UTC
@snwbrdwndsrf Hmm good idea - i think i'll go ahead and give that a try
snwbrdwndsrf @shaka wheeler 5 April 2017, 16:02 UTC
Awesome. Let me know how it turns out, @shaka-wheeler.
Ttimvdp @shaka wheeler 6 April 2017, 14:12 UTC
@shaka-wheeler said in Corner scraping:
alu corners or rollers these things will keep you sliding more instead of stopping(is why you were pushing down?..)...bumbers are made to be used and replaced. just don't mind it
magicrobots 6 April 2017, 17:04 UTC
Use them like roller skate brakes?
mekon 6 April 2017, 17:10 UTC
@snwbrdwndsrf @shaka-wheeler
hmm... wonder if this stuff would work for the aluminum too. -
Post(s) 20-21 are missing from the archive :(
