Squeaky wheel
calejr 6 August 2017, 21:16 UTC
Ok, my OneWheel+ just started making a squeaky wheel noise on each rotation above approx 6mph. Do I just need to ride it a while to work it out or oil it or something? Just searched the forum for some advice but couldn't find anything. Thanks!
MrCamel @calejr 7 August 2017, 06:25 UTC
Hi @calejr, very good question, mine also makes a squeaky noise, but it comes and goes. Usually on my morning commute more than my afternoon return. Cold mornings it seems worse. It does NOT sound like the wheel. More the computer. very interested to hear if you get to the bottom of this issue.
My board has about 800km (500Miles) on it. -
groovyruvy @calejr 7 August 2017, 15:25 UTC
@calejr @MrCamel can you post a clip with the audio of this noise so we can try to diagnose?
MrCamel @groovyruvy 8 August 2017, 01:40 UTC
@groovyruvy Yep I'll try to remember to record it next commute.
calejr 8 August 2017, 23:40 UTC
Here is a video - seems to now happen at any speed up to about 13 mphish 80% of the time I ride. I haven't noticed any consistency to when it happens at low speeds and when it doesn't. leaning doesn't seem to affect it either:
@groovyruvy @MrCamel
groovyruvy @calejr 9 August 2017, 01:23 UTC
@calejr well you know what they say . . . . . the squeaky wheel gets the grease :) (sorry, couldn't resist). I listened to the audio in the clip you posted several times, and through the road noise and the 'whirring' of the wheel (both of which are normal) I'm hearing that whining sound, which isn't normal. I can't say what the issue is for sure, but it's possible you have a bad controller module. One of my Originals was making a weird digital noise, it sorta sounded like static mixed in with a Star Wars droid-type language. It came and went but when it came it was loud and noticeable. The board seemed to work fine, but the noise concerned me and it bugged my bros when we rode. I sent it in to FM, they diagnosed the board and isolated the issue to the controller module. They replaced it and sent the board back to me, the noise is gone. Couple long shots here: make sure there's nothing wrapped around the axle, and nothing's jammed between the footpads and the tire. Possibly maybe could be a poorly seated tire (you could deflate it and then reinflate) but if that were the case the board would feel wobbly and I didn't see any of that in your video. Hope this helps.
AAT_onewheeler 10 August 2017, 07:33 UTC
Hello, i noticed that squeaky noise too. But not at all Speeds. So I'm riding regular and noticed with every toeside carv it gets louder and with heelside carvs the noise is gone.
If I am brave enough to film it while riding i will do, but at this time i practice with free Hands ;) haha
doesn't hope theres a bad Controller module @groovyruvy because i only own it three days and won't ship it back from europe :(Also installed the Fender today and another noise Comes up but I think These are the (i dont know the word, i mean this wheel "hairs") "Pins" at the wheel which brushes the Fender. Maybe will go when the wheel is more used
Polle @AT_onewheeler 10 August 2017, 12:10 UTC
@at_onewheeler
When there is a malfuntion on the board, FM will pay for shipping and repair, so don't worry.
The extra noise with the fender can also be some echo and small pebbles hitting the fender. -
AAT_onewheeler 10 August 2017, 12:24 UTC
@Polle thanks for your time. But we don't definately know if it is a malfunction. Would it help to send the diagnostic trough the app?
Polle @AT_onewheeler 10 August 2017, 14:55 UTC
@at_onewheeler Best is to open a ticket at FM's support, they will probably tell you to make a video and send it to them...
calejr 11 August 2017, 12:30 UTC
Update/non-update:
Now the board makes the noise at 0 to approx 8mph about 75% of the time I ride in any given session.
So, basically, it's not consistent.I opened a ticket with support. They asked for my serial # (sent) and if I could recreate the sound by manually turning the wheel with the power off. First attempt I was unable to, but then the board stopped doing it when riding normally so inclusive. Will try again next time I hear it.
calejr 11 August 2017, 23:22 UTC
Update/non-update 2:
New firmware update - no change. Got the noise again. Def sounds like it's coming from the right side of the wheel (toe side).
I like the new modes tho! -
AAT_onewheeler @calejr 18 August 2017, 08:54 UTC
@calejr my noise also come back and it definately Sounds louder than before. But then it gets a little better. Now i have filmed it an opened also a ticket and hope only a bit of oil is necessary haha. But i won't try it on my own because i fear of loosing the warranty.
Thats the link for the vids: https://drive.google.com/drive/folders/0B7PPHnT7zRJ5VThEZG5Ia0tNUTA -
groovyruvy @AT_onewheeler 18 August 2017, 14:46 UTC
@at_onewheeler yeah that's an annoying sound. I did the update and don't have anything even close to that, however a lot of riders have been reporting issues since the firmware update. Some of my riding bros have had their board bricked (it no longer turns on, or off, so it can't be ridden) and a lot of guys on the FB page are reporting noises ranging from grinding sounds to the squeak you've got. Weird how different boards are reacting differently to the update.
AAT_onewheeler @groovyruvy 18 August 2017, 20:21 UTC
@groovyruvy yeah I read also about that issues and noises but this noise also appeared before the update.
Don't really know about riding or not. Hope support answers soon -
groovyruvy @AT_onewheeler 18 August 2017, 23:12 UTC
@at_onewheeler one of our riding bros resolved the grinding noise by removing the wheel and tightening down the two Allen bolts, after that it was much quieter
AAT_onewheeler @groovyruvy 19 August 2017, 04:31 UTC
@groovyruvy that sounds in a way logic but I don't want to void my guaranty for only pulling on two screws
SC720 @AT_onewheeler 20 August 2017, 04:31 UTC
@at_onewheeler Send your videos to support if you haven't already. They will probably ask for one when they get back to you so save yourself a step. They will likely just advise you to send it in at their expense. If you can be patient with that repair process then the peace of mind of a properly functioning board will pay off.
AAT_onewheeler @SC720 20 August 2017, 08:02 UTC
@sc720 hey thanks. Already send my vids to support 3 days ago
Hope they offer me a good solution, if i have to sent it in I will do. A short period of no ow is better than time with an issued ow. But hopefully only greasing is enough like @groovyruvy was joking at first haha ;) -
cascadewheeler 20 August 2017, 20:06 UTC
Your not gonna void your warranty by tightening a couple screws. That would be ridiculous!
AAT_onewheeler @groovyruvy 20 August 2017, 20:28 UTC
@groovyruvy said in Squeaky wheel:
@cascadewheeler yes that's true. I don't know if I studied the manual correctly but removing the wheel is a way for void warranty or I am wrong?
But it must be a simple thing because it is coming and going away on its own. Haven't figured out why the noise starts or stops
Hope support answers tomorrow -
PowerWheel5000 31 August 2017, 11:57 UTC
This just happened to me. Had a squeaky plus for a few days. Problem went away on its own. Really curious what it was
Jjwheelin @AT_onewheeler 23 January 2018, 03:17 UTC
@at_onewheeler
I have the exact issue, I ride goofy and get it when I ride toe side, every once in a while it goes away but usually returns a day or so later, what was FM’s advice to you, did you fix it ? WD40?
AAT_onewheeler @jwheelin 23 January 2018, 11:07 UTC
@jwheelin no please don't use wd40. Julian at the forum said please never use wd40 for the onewheel. I don't remember the exact reason for that.
I opened a ticket at FM and they don't solved it remotely. So I had to send my board in. But then I was at vacation and some other troubles began with my board. So more things have to been repaired by FM. But I never got it back because FedEx lost my board after picking it up. So I don't know if the repairs worked :( very sad about it. FedEx offered fm a 750$ insurance value. So I hope fm is customer friendly and they replace my lost board. Because it was only on use about 3 months. -
glisse84 @AT_onewheeler 23 January 2018, 11:57 UTC
@at_onewheeler Hi everybody,
This is really annoying from FM that they impose we don't "touch a screw" as we have issues with our OW's and to be obliged to send/seperate from it for so (seemly) little things.
In this case of noise, couldn't it be a problem of axles' alloy quality that has been prematurely worn down?
The FMs' attitude asking not to touch anything on our boards could stem from them not willing we discover where materials come from or how they're made?
Many comments I read on this forum make me think FM is not so honest and don't deserve to get all the money we give them for such a quality's product.
They know they have a "gold mine" with the OW and us as addicts, and want to preserve their incomes without spending for the quality we're waiting for.
I don't pretend it's the truth but a possibility and that's a bad feeling.
Wish I mistake ;-)
