Range onewheel+
Cyberaw 15 August 2017, 21:57 UTC
Could you tell me your real maximum range on the onewheel+?
sonny123 15 August 2017, 22:11 UTC
Delirium is juice thirsty.
I come back from my 4 mile run with about 20% left.
Before Andromeda update, it was somewhere around 29%
Ironically, my V1 range got better with time.
So I wouldn't be surprised if my + range increases overtime. -
GlueBreath @Cyberaw 15 August 2017, 22:30 UTC
@cyberpan I'm regularly hitting 6.5 miles on mission and 6.0 miles on new delirium shaping per charge post FW update.. I'm 210lbs and ride @ 20psi.
@sonny123 that has been my experience with the plus.. I started off getting around 5 miles per charge on mission out of box and now I just hit 800 miles on my plus and the range has increased by over a mile since.. the most I have gone is 6.8 miles on a charge.
groovyruvy @GlueBreath 15 August 2017, 23:25 UTC
@gluebreath what kind of riding are you doing that gets you that mileage- more street? Just asking as you and me are the same weight and PSI and at least on the old Mission I'd be lucky to get 5 miles out of a hard charging cross-terrain ride.
GlueBreath 16 August 2017, 00:04 UTC
@groovyruvy yes that's on mostly flat street/sidewalk cruising @ 15-16mph.. there is no hills or off road trails of any kind near me.. I started off only getting around 5 miles per charge on mission but over time it has increased to 6.5 miles.. what's odd is once I hit 1% I'm still able to ride for another mile or so.. it always says I regen over 20% battery each ride.. I'm definitely not complaining.
Ccelebro 16 August 2017, 18:54 UTC
My ride yesterday cruising for 10.59
mil.
GlueBreath @celebro 16 August 2017, 19:16 UTC
@celebro that's impressive!.. you must be light weight and ride a high tire psi.. that's definitely not typical.. FM's stated range of 5-7miles is pretty spot on for "most" riders.
Ccelebro @GlueBreath 16 August 2017, 19:20 UTC
@gluebreath it was mostly sidewalks and asphalt. The tire PSI is standard out of the box. I'm 160 lbs and 5.8". That was my first long ride after upgrading to Andromeda. So far I have 72 miles on it.
thegreck @celebro 16 August 2017, 21:16 UTC
@celebro I don't think there's really any standard psi out of the box. You should figure out what psi works best for you and then check it regularly to keep it there.
Removing the last digit from your weight is a good starting point. So if you weigh 180, try 18psi and go from there, just not above 20psi.
sonny123 17 August 2017, 01:30 UTC
Thought I'd keep going until it drops dead.
Not bad for 225 lbs
PPixelPusher 17 August 2017, 20:50 UTC
8-10 miles on a charge.. 190lbs, mostly flat streets and sidewalks.
cascadewheeler 17 August 2017, 20:55 UTC
whats the board do as the battery dies? just get slower and slower till it drops and stops or is it abrupt?
Ssimtech @cascadewheeler 17 August 2017, 21:12 UTC
@cascadewheeler it starts to give pushback at slower speeds until it eventually craps out.
sonny123 @cascadewheeler 17 August 2017, 21:20 UTC
@cascadewheeler
At 1%, you'll have little bit of cruising time before getting severe pushback indication and then it'll just stop.
Ccelebro @thegreck 18 August 2017, 00:25 UTC
Mmcguiles 23 August 2017, 01:00 UTC
if I really want to get a lot of range I can get 8 to 10. but carving and riding aggressively i'll get six, always.
Mmcguiles @mcguiles 24 August 2017, 00:47 UTC
@mcguiles
this was my "slightly aggressive" ride today in Denver.
Ffruitygreen 24 August 2017, 01:19 UTC
Delirium mode I get only 1 mile on sand.
With threaded tire there's a lot of traction and the power of the plus I go places that are fun.Beaches and dirt hills are my favorite but the 1 mile range makes me wanting more.
Ffirephreek @PixelPusher 24 August 2017, 12:59 UTC
@pixelpusher How aggressively are you riding to get that range? I'm 207 and only managed to get 4.5 miles in Mission riding from Lower East Side to Upper West here in NYC. Realllly disappointing since I live just barely 6 miles from where I started...
OOnewheel Miami @celebro 24 August 2017, 16:09 UTC
@celebro We should ride. I tend to run the upper east side regularly.
Ccelebro @Onewheel Miami 24 August 2017, 16:52 UTC
@ow-miami cool lets meet. When and wher. I was thinking of starting a group or something like that in Miami. Let me know.
Ffun2ride 31 August 2017, 12:29 UTC
I am 176 lbs and I ride on 18PSI.
With mission setting (if I ride on flat surface) asphalt, I can get up to 6.4 miles. (this was the largest distance I could ever get) with 5% left.
When I try riding grass in Delirium mode mixed with Mission on flat surface I get about 4.4 miles with 4% battery left.
Today it took me 30 mins to drain my battery to 4% and just over 4.3 miles. This is a very short time to enjoy riding. :-(At the end of my ride Battery Cells I have are around : 3.20 each and Total battery voltage is : 51.4V
At the beginning fully charged battery cells are around 3.60 and total battery voltage is : 58 VThank you all.
-D. -
OOnewheel Miami @celebro 31 August 2017, 17:19 UTC
@celebro
For any who read this - there's a south florida onewheel group on facebook.
drydockml 30 September 2017, 20:58 UTC
On a related note, has anyone ever tried this backup battery charger from Coolis?
https://www.amazon.com/dp/B01N4H2P2T/ref=cm_sw_r_cp_api_eqa0zbRAY0149
Curious if it gives enough voltage, how many charges does it give? Thx!
BBRAGeorgia 2 October 2017, 19:05 UTC
I'm 6'3 225lbs. Typical urban riding with hills mixed in I get around 4.2 miles. Longest I have ridden on one charge is 6 miles on flat and smooth road.
skyman88 @BRAGeorgia 3 October 2017, 10:58 UTC
@brageorgia said in Range onewheel+:
Which shaping do you ride in?
groovyruvy @BRAGeorgia 3 October 2017, 14:26 UTC
@brageorgia at 5' 8" and 209# I'm in the same boat with you. I get between 4.2 - 4.9 miles in Delirium during a hard-charging ride. If I'm just cruising on flat hard ground I can squeeze 6 miles out of it but it's not as fun :)
GGwinntanamo 4 October 2017, 19:45 UTC
I am 190lbs, and often have 10lbs of gear with me.
I ride hard, carving a lot, and get >7 miles out of a full charge. That is up from the 4-5 I was getting when I had my Vega tire at 20psi. I now ride with the Hoosier @ 45psi. It's a dream.
Post(s) 28-39 are missing from the archive :(
