V1 issues!
TJ04 12 September 2017, 00:49 UTC
Rode my onewheel up a hill on Sunday evening and then all of a sudden the motor cuts out on me for no reason! - Happened twice! 🙁
Managed to get back home ok, board seems to be working fine.
Pretty much lost my lifetime Miles (1,978 miles)
Also noticed it automatically switched back to classic mode, anyone know what's causing this? -
pat_hurley 12 September 2017, 01:52 UTCP
What battery percentage were you on? i would check the readings on the cells as well
TJ04 @pat_hurley 12 September 2017, 10:57 UTC
@pat_hurley All cells look balanced.. battery percentage is a little bit messed up, it doesn't give me accurate readings.
I have to keep looking in "board settings" all the time!Had about 30% battery power left when I got home.
thegreck @TJ04 12 September 2017, 18:47 UTC
@tj04 Def shouldn't switch back to Classic without you doing it manually.
wr420 12 September 2017, 22:16 UTCW
I have had a similar problem but the symptoms only showed up when the board was cold(first ride of the morning) and til it warmed up.
The board would shut off, mileage reset to zero, and reset to classic.
The BMS was replaced and it took care of the problem. -
TJ04 @wr420 14 September 2017, 03:30 UTC
@wr420 said in V1 issues!:
The BMS was replaced and it took care of the problem.👍, Will definitely send my board back to FM, see what they have to say. 🙂
