Charging me for a Circuit Board Manufacturing Defect
WoWo 25 October 2019, 17:13 UTCW
I recently sent in my 10 month old board in for repair with 780 miles on it.
I was told there was water damage, but the pictures showed Corrosion near the Powered edge of the Circuit board... This is obviously because the Circuit Boards are not conformal coated: meaning they are not coated with a fingernail polish type material that will eliminate the chance for corrosion on the Circuit Boards.
I was charged for a New Battery Case, shipping and handling, and labor for this design/manufacturing issue..
These Circuit Boards should last longer than 10 months in the environments you advertise on your website.
Refund request...Please help...
Taranis 6 December 2019, 10:30 UTCT
Your battery has only 6 months warranty
UTrider @WoWo 6 December 2019, 14:33 UTCU
@WoWo said in Charging me for a Circuit Board Manufacturing Defect:
I've looked at the website again. Not sure what environments your talking about. Everything on the page shows dry conditions. No rain. No snow. No wet trails.
OneDan+ @WoWo 6 December 2019, 17:56 UTC
@WoWo Posting here won't get @Future-Motion to respond, you have to call them directly. I called a couple of days ago and, while I waited on hold for some 15 minutes, someone did eventually answer. Which is way better than in the past when you'd hold for 2 minutes, then it would hang up on you!.
