Battery pint failure
nemo801 15 January 2021, 08:46 UTCN
My Onewheel Pint with only 4 months old sends me a message that it needs to be recharged with 20-40% battery left, I have been charging for several days to calibrate the cells and even so I still get an error and I cannot use the Onewheel for fear of stay put,🥺🥺🥺
NotSure 15 January 2021, 13:55 UTC
Have you run the battery down to nothing? As in the board shuts off after
LED's turn red?https://archive.owforum.co.uk/topic/9300/is-my-pint-broken/17
stinkyface @nemo801 16 January 2021, 07:40 UTC
@nemo801 the charger does what's called a top balance. I.e. charges cells to the top of the voltage range.
Draining the battery by running it flat in a milk crate or similar does what's called a bottom balance (bottom of the voltage range). Don't do bottom balancing too often but it might help in this case.
If the bottom balance doesn't fix it, a cell is dying and you should pursue a replacement battery under warranty.
